512 Assembly Is Under Way!! #703140
05/20/10 11:12 AM
05/20/10 11:12 AM
tboomer Offline OP
tboomer  Offline OP
Just got a call from bad1970dust(Jimmy)..The block is back from the machine shop and assembly is under way...Sounds like the Muscle Motors rotating assembly went together without a hitch!! I can't wait to drive this thing!! Thanks,Jimmy!!
Re: 512 Assembly Is Under Way!! [Re: tboomer] #703141
05/20/10 11:15 AM
05/20/10 11:15 AM
ill
dennismopar73 Offline
ill
great news
be going fast soon
Re: 512 Assembly Is Under Way!! [Re: tboomer] #703142
05/20/10 11:26 AM
05/20/10 11:26 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Great news....Why don`t you assemble your own motor out of curiousity?
Re: 512 Assembly Is Under Way!! [Re: Thumperdart] #703143
05/20/10 11:29 AM
05/20/10 11:29 AM
tboomer Offline OP
tboomer  Offline OP
Thanks,Dennis...Thumpman...I do not have the skills or the tools to do such a job..Jimmy is a perfectionist when it comes to an engine build...When he says he is giving me 700 HP...You can take that to the bank!!
Re: 512 Assembly Is Under Way!! [Re: tboomer] #703144
05/20/10 11:49 AM
05/20/10 11:49 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Gotcha You do what ya gotta do.......... All I can say is , HANG ON......
Re: 512 Assembly Is Under Way!! [Re: tboomer] #703145
05/20/10 11:52 AM
05/20/10 11:52 AM
ill
ill
what is the bank account number ha ha
went to the track tue
to test new 543 in 67 coronet
wasnt good news 1 run all kinds of
bugs
this motor has been a curse
if had time i would detail it
but that is off topic
Re: 512 Assembly Is Under Way!! [Re: Thumperdart] #703146
05/20/10 11:53 AM
05/20/10 11:53 AM
GA
Boosted Offline
Boosted  Offline
GA
Cool my 512 is in th works also.... Should be driving it next month
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: 512 Assembly Is Under Way!! [Re: Boosted] #703147
05/20/10 12:05 PM
05/20/10 12:05 PM
tboomer Offline OP
tboomer  Offline OP
Good luck!! Maybe I should post a Whats it gonna run thread!! It should push the old boat down the track pretty good!!
Re: 512 Assembly Is Under Way!! [Re: tboomer] #703148
05/20/10 02:06 PM
05/20/10 02:06 PM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
Just out of curiosity (sp) ?
What is a ball park figure to build a 512 ?
I will be getting a muscle motor kit also.
Just the short block.
Re: 512 Assembly Is Under Way!! [Re: demon440] #703149
05/20/10 05:57 PM
05/20/10 05:57 PM
tboomer Offline OP
tboomer  Offline OP
A second mortgage comes to mind....
Re: 512 Assembly Is Under Way!! [Re: tboomer] #703150
05/20/10 06:02 PM
05/20/10 06:02 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
and the left and right side of the anatomy...
Re: 512 Assembly Is Under Way!! [Re: smokinwoody] #703151
05/20/10 09:41 PM
05/20/10 09:41 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Good for you Ted!!! I am happy for you buddy!! Can't wait to see all your "new best" post's!!
Re: 512 Assembly Is Under Way!! [Re: demon440] #703152
05/21/10 01:48 AM
05/21/10 01:48 AM
Alberta, Can
JUST_N_TIME Offline
JUST_N_TIME  Offline
Alberta, Can
512 - 700hp - carb-pan 12Gs
anyone else?
maybe boomer will let us know after its delivered.
Re: 512 Assembly Is Under Way!! [Re: JUST_N_TIME] #703153
05/21/10 02:15 AM
05/21/10 02:15 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I think the stroker kit is around $2,000?
Heads with good springs/retainers/rockers $3,000+?
Roller cam/lifters/timming chain/pushrods $1,000?
Intake/carb $1500?
Oil pan/pump/windage tray Maybe $500?
machine work $1000-$1500?
So maybe $9,000 if you can do the assembly and reuse ignition/water housing and pump/pulleys/radiator and exhaust?
Add some trick parts or porting and I'm sure the cost will go up. You may be able to do it a bit cheaper too, but I think it would be difficult at the 700 range without compromising durability?
The place where you could save some $$$ is if you can get a good used intake and carb and/or oil pan?
Re: 512 Assembly Is Under Way!! [Re: 451Mopar] #703154
05/21/10 03:24 AM
05/21/10 03:24 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
Intake/carb $1500?
naaa... your way high on those numbers
Re: 512 Assembly Is Under Way!! [Re: 451Mopar] #703155
05/21/10 09:17 AM
05/21/10 09:17 AM
ill
ill
$1400 storker kit new
heads new , $1499
block used $200 bare?
cam new $300,with lifters
intake ,new $250
machine work around $900
stud kit $150
gaskets $350 with cametic??
oil pan w pickup $150
water pump housing aluminum ,$125
water pump $30
total $5285.99
just a rough guess
you can get it done around the $4800 area
am i close enough
Re: 512 Assembly Is Under Way!! [Re: 493_DART] #703156
05/21/10 10:26 AM
05/21/10 10:26 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Intake/carb $1500?
There may be some margin in the numbers for small stuff like gaskets and hardware
I could go get all my bills and add them up to see the actual cost, but I did my build over a few years and for two engines so I would need to seperate out the costs of each engine.
Re: 512 Assembly Is Under Way!! [Re: dennismopar73] #703157
05/21/10 10:34 AM
05/21/10 10:34 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
heads new , $1499
intake ,new $250
stud kit $150
water pump $30
total $5285.99
just a rough guess
am i close enough
That sounds more like a 500 HP engine?
You would be limited to the springs/retainers of the $1500 heads, and $300 for cam/lifters limits you to a flat tappet cam?
Re: 512 Assembly Is Under Way!! [Re: 451Mopar] #703158
05/21/10 12:28 PM
05/21/10 12:28 PM
tboomer Offline OP
tboomer  Offline OP
Here is some costs...Sure I will forget something..
Muscle Motors 512 kit...2029.00
Block...Don't know...It was Jimmys,I have to replace it with another..
Machine shop...Over 500.00
New roller cam and springs bought from Russ(Old Racer) 160.00..Profiled at Comp Cams..40.00
Roller lifters,stud kit,new oil pump,bronze drive and other stuff from Summit Racing..Around 1000.00..I already have the MP heads,M-1 intake and carb..Static pickup from the Source..55.00. New Mallory billet dual point Dizzy...20.00 from a swap meet guy..Also thru in a low deck Uni-lite..(needs repair)..This is just a few things I remember...There will be more stuff,I am sure...
The look on my face when I drop the hammer the first time...Priceless,Baby!! I am very stoked about this build and Jimmy is a professional on his builds! He can build anything at his shop but prefers Mopars!! I strongly reccomend him for anyone needing chassis work,engine builds or tranny work..
Re: 512 Assembly Is Under Way!! [Re: tboomer] #703159
05/21/10 12:38 PM
05/21/10 12:38 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Wait, Wait, Wait a minute, I thought you were builting a 383.....
