Hey guys I have a problem with the accelerator pump on a 72 smallblock thermoquad. The problem is it doesn't work at the initial crack of the throttle. I took it apart, the pump had a small crack in it, put a new check valve, pump, line, and needle in it. Put it back together, same issue.
It looks to me the spring in the accelerator pump is what actually activates the pump when the throttle is cracked. I don't have another one. Anybody know if there are stronger ones available, the rebuild kits I have don't come with one.
Any books avail to help a noob on these things?
Thanks guys
