Thermoquad Help. #702232
05/19/10 07:53 AM
05/19/10 07:53 AM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
Hey guys I have a problem with the accelerator pump on a 72 smallblock thermoquad. The problem is it doesn't work at the initial crack of the throttle. I took it apart, the pump had a small crack in it, put a new check valve, pump, line, and needle in it. Put it back together, same issue.
It looks to me the spring in the accelerator pump is what actually activates the pump when the throttle is cracked. I don't have another one. Anybody know if there are stronger ones available, the rebuild kits I have don't come with one.
Any books avail to help a noob on these things?
Thanks guys
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
Re: Thermoquad Help. [Re: F1Scamp] #702233
05/19/10 08:10 AM
05/19/10 08:10 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
The spring for that should be cone shaped.
Check the linkage. Sometimes you need to adjust the pump rod(bend it) so the pump is positioned high when the throttle is in the idle position. I would also check the actuator mechanism on the throttle shaft. If you have an untouched carb to compare yours to that may help track down the problem.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Thermoquad Help. [Re: Rapid340] #702234
05/19/10 08:13 AM
05/19/10 08:13 AM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
The pump is alittle over 1/2" up in idle position, when you crack the throttle, it doesn't move until it is forced to move by the linkage on the throttle shaft, which is over 1/2throttle. I need it to move instantly when hitting the throttle.
Re: Thermoquad Help. [Re: F1Scamp] #702235
05/19/10 08:20 AM
05/19/10 08:20 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
It sounds like the rod it too short (too much bend in it).
Re: Thermoquad Help. [Re: Rapid340] #702236
05/19/10 08:27 AM
05/19/10 08:27 AM
SE Kansas
I
indytex96 Offline
indytex96  Offline
I
SE Kansas
I just rebuilt the thermoquad on my 74 400 and have kinda the same issue with a slight hesitation during part throttle. Would that mean I need more or less travel on the acc. pump?
Re: Thermoquad Help. [Re: Rapid340] #702237
05/19/10 08:48 AM
05/19/10 08:48 AM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
If I take the rod out of the equation, I have to give the pump alittle help then it sucks down. I really think I need a stronger spring
I will try lengthening the rod to see if it helps.
Re: Thermoquad Help. [Re: F1Scamp] #702238
05/19/10 09:00 AM
05/19/10 09:00 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
The pump should not need any help to move. There is a problem with the spring or the pump is somehow getting caught.
Re: Thermoquad Help. [Re: Rapid340] #702239
05/19/10 11:58 AM
05/19/10 11:58 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Can you stretch the spring Brian?
Re: Thermoquad Help. [Re: scatpacktom] #702240
05/19/10 01:33 PM
05/19/10 01:33 PM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
I did alittle bit. It has rust on it, and the pump had a crack in it. I think its just plum worn out. I also tried getting ahold of the guy that built it too...
I have one built for a SS car, but under strict instructions not to take the top off. Afraid I might need alittle more fuel..
