70' 440 engine block color
#70213
06/08/08 11:41 PM
06/08/08 11:41 PM
a 70' 440 6pack motor is suppose to be painted what color? my car's not a real V code, but I want to make it look correct.
Chrysler Hemi Orange? I believe that is the color, any brand reccomendations? I was thinking about picking up a can of the duplicolor rattle can from pep boys.
Also what blocks were painted with the race hemi orange? I also saw restoration hemi orange? Are they the same?
Re: 70' 440 engine block color
#70217
06/09/08 01:42 PM
06/09/08 01:42 PM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
The correct color for a 440 engine was called Omaha orange by the Chrysler Corporation. There were a couple of other names used but Omaha orange is the correct hue for the time period around 1970. Keep in mind that even though each plant used the same formula and color of paint, there were variations with the colors. Hemi engines were assembled and painted at a completely different facility and most people incorrectly use that engine's color code for their non "Hemi" orange engines. The black component assemblies that were bolted to the engine used two different black color variations for most of their applications. Another misconception with black components relates to the gloss or finish of the part. Pulleys were manufactured, by a subsidized independent supplier that was commissioned by Chrysler. The same goes for the power steering components, other related brackets or air conditioning parts. It would be impossible for these components (that were made by the various manufacturers in different parts of the country) to have pieces that were perfectly matched in color and sheen. While restoring the 440 in my Challenger we accumulated NOS or low mileage samples to determine the "family" of color and/or finish that was used for each component. Every black accessory on the engine should slightly vary, depending on the application and part. For instance, the A/C components should all have the same look (being made at the same manufacturing facility) yet be slightly different in finish or sheen than the power steering components, etc.
#70221
06/11/08 02:56 AM
06/11/08 02:56 AM
so I've got an extra can of chevy orange lying around...................
[Re: gomangoRTSE]
#70224
06/11/08 12:42 PM
06/11/08 12:42 PM
Posts: 57 Warren, Michigan
70_challenger
Warren, Michigan
There are some paint codes around here somewhere I have for the Dupont, PPG, but they are on my other computer.
I would like to see those paint codes. If you could post them when you have access, that would be appreciated!
Dave: Do you have a paint code for the mixture you ended up using?
Thanks, guys.
-Tom
