Re: 91 Spirit...speedo and odometer not working... [Re: dusturbd340W5] #70200
06/10/08 08:17 PM
06/10/08 08:17 PM
Morningside
AdventurerSport Offline
waaaay out there in left field
Morningside
My '91 Acclaim did that a few years ago...no speedo/odo, no code, but changed the sensor and been fine ever since...almost 80,000 miles ago...:)
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red
06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II
06 Chrysler 300C AWD 5.7L Hemi
10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI
10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI
11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red
16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
Re: 91 Spirit...speedo and odometer not working... [Re: AdventurerSport] #70201
06/11/08 10:50 PM
06/11/08 10:50 PM
Anacortes, WA
russ71satellite Offline OP
Anacortes, WA
just checked for codes, and I'm getting a 38. this is a 3.0L. Does anyone know what this code is?
Also, when I turn the key quickly to read the code, occasionally the speedo needle pegs, then goes back down. What does that mean?
71 Satellite Sebring, all stock
1989 Dodge Daytona, daily driver
2008 PT Cruiser
Re: 91 Spirit...speedo and odometer not working... [Re: russ71satellite] #70202
06/12/08 10:21 PM
06/12/08 10:21 PM
Anacortes, WA
Anacortes, WA
bump...
speedo needle bounces and pegs while I turn key to read codes...any ideas what that means?
2008 PT Cruiser
Re: 91 Spirit...speedo and odometer not working... [Re: russ71satellite] #70203
06/13/08 09:27 AM
06/13/08 09:27 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
shop key shows 38 being lock up control problem
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 91 Spirit...speedo and odometer not working... [Re: dusturbd340W5] #70204
06/13/08 11:16 PM
06/13/08 11:16 PM
Anacortes, WA
Anacortes, WA
Replaced the speed sensor today, but no help...
2008 PT Cruiser
Re: 91 Spirit...speedo and odometer not working... [Re: russ71satellite] #70205
06/13/08 11:19 PM
06/13/08 11:19 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
You were already there to replace the sensor. It wouldn't hurt to check the plastic gear. I've seen them get stripped on a 727. I'm sure it's possible on your as well. If you clean up the sensor good enough you might be able to take it back and say you didn't install it.
Re: 91 Spirit...speedo and odometer not working... [Re: burdar] #70206
06/13/08 11:25 PM
06/13/08 11:25 PM
Anacortes, WA
Anacortes, WA
the gear looks good. It was of course attached to the old sensor, but I checked it and clipped it onto the new sensor.
2008 PT Cruiser
Re: 91 Spirit...speedo and odometer not working... [Re: russ71satellite] #70207
06/16/08 09:54 AM
06/16/08 09:54 AM
stratford,ontario,canada
JD340 Offline
JD340  Offline
Hey Russ, it's the Hijacker here. Messed around with my Neon the better part of Saturday. New speed sensor=NO change. Started tearing into gauge cluster. Poor connection between cluster and dash wiring. Gave terminals a little twist to improve connection. Result: still intermittent at best. Built up terminals with a little solder. Same result! Maybe there is a break in the wiring somewhere. I haven't found it yet! I feel your frustration with this. We probably put 10-15 miles on the car, on the hoist trying to find the "sweet" spot where the speedo would run consistently. If we ever trace it down, I'll give you a heads up.
Nothing to see here. Carry on.
