Upholstery experts; HELP! #701540
05/18/10 06:23 PM
05/18/10 06:23 PM
Omaha, Nebraska
Scott Carl Offline OP
Omaha, Nebraska
What kind of adhesive can I use to bond vinyl to plastic door panels on Challenger. They're oxidized but I have scraped all of it off down to good plastic. I need an adhesive that bonds well but won't dissolve the vinyl or panel. I heard something like 3M or Weldwood contact cement could dissolve the vinyl. Any upholstery guys out there??
Re: Upholstery experts; HELP! [Re: Scott Carl] #701541
05/18/10 11:51 PM
05/18/10 11:51 PM
Northern Territory, Australia
Z
Zapp Offline
Zapp  Offline
Z
Use a 3M spray on contact adhesive, be careful that the panel is flat as the vinyl will show up any defects below. the texture of the original panel will show through which is fine if it is everywhere but as you said you've scraped away some oxidized area so these may be smooth
Re: Upholstery experts; HELP! [Re: Zapp] #701542
05/19/10 10:09 PM
05/19/10 10:09 PM
Omaha, Nebraska
Omaha, Nebraska
After re-reading in Don Taylor's auto upholstery book I realize its more about the glue to foam rubber issue than glue to vinyl, but thanks, Zapp, for the reply. I'm gonna do some R&D before I do anything permanent, But I couldn't make my door panels look too much worse LOL.....or could I?!?
Re: Upholstery experts; HELP! [Re: Scott Carl] #701543
07/05/11 11:29 PM
07/05/11 11:29 PM
Z
Zapp Offline
Zapp  Offline
Z
Hey Mate! How did the door panels turn out?
