Stroker 400? #701099
05/18/10 02:58 AM
05/18/10 02:58 AM
Iowa
76dodgeboy Offline OP
Iowa
Ok I have the 400 block and I got a free 440 but plan to go look at another 440 thats tore down but My question is What has to be done to make my 400 a stroker other than a 440 crank? Do I use 400 or 440 rods? What needs machined? What pistons? Balancer? Thanks in advance
Re: Stroker 400? [Re: 76dodgeboy] #701100
05/18/10 03:58 AM
05/18/10 03:58 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
It seems that alot of people are jumping on the "Stroker" bandwagon lately. They are a great way to build power, but they certainly do add to the cost of the build. ARE they really worth the bragging rights? What are your power goals? You may find that simply building a nice stock stroke 440 will provide plenty of power with less hassle. The first popular 400 based stroker engines used 440 crankshafts and 383/400 rods using custom pistons. Now you can get a kit in a box with all new stuff. 440 Source offers low priced stuff. Quality seems good. I went with Hughes for my 440 based 493 engine. This motor is overkill for me, and I doubt that I will need to build a stroker again. I only drag race once in a blue moon. The car sees less that 500 street miles per year. The Stroker engines sound cool and trendy, but a stock stroke engine can still make plenty of reliable power.
Re: Stroker 400? [Re: Kern Dog] #701101
05/18/10 04:16 AM
05/18/10 04:16 AM
Hartselle AL
67MIke Offline
67MIke  Offline
Hartselle AL
yeah, I was looking at a 451 for my truck, I think a decent 440 will take care of my needs though...
without the extra hassle.....
Re: Stroker 400? [Re: 76dodgeboy] #701102
05/18/10 06:36 AM
05/18/10 06:36 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
The 440 crank has to have the mains cut down to 383/400 size, most have the counter balances cut down a bit while it is at the crank place as sometimes the counterbalances hit. or you can mock up and see and grind the block a bit if need be. If you use aftermarket rods you may have to grind a wee bit at the bottoms of the cylinders very slight.
You can use 440 or 383/400 rods pistons are available for either way. I would suggest new H beam rods as by the time you buy new rod bolts , re size, and R&R the pistons they are close to that cost and pistons will be full floating and R&R is remove and replace the spiro locks with the H beam rods.
Your really building a .055 over 440 (+ .030 400 block) in lower narrower block great to get 440 pop where room is an issue like a dart or A body cuda plus the block is 30 or so pounds lighter than a 440 block.
If room is not a issue I would just build the 440 based 446 or 452 (+.030 or +.060). a comparable built 400/451 and a 440/452 will make the same power so it's kinda not a stroker but is a stroker to a 383/400.
That said a 500 to 512 kit in a 440 block (or the 400 if room is an issue) is about the same price as a total rebuild of a 440 or a 440 crank to 400 swap so that would be the way to go. obviously there are some girly men out there that are better suited to 318's but most of the rest of us are BIGGER BETTER FASTER type of guys.
hard to beet all in one kits when you do all your math.
http://www.440source.com/strokerkits.htm
or'
http://chucker54.stores.yahoo.net/nonbalanced.html
balanced
http://chucker54.stores.yahoo.net/inba.html
hope this answers some questions.
Re: Stroker 400? [Re: 76dodgeboy] #701103
05/18/10 10:03 AM
05/18/10 10:03 AM
AndyF Offline
AndyF  Offline
There are a lot of stroker articles in the tech archive area. There is also a lot of info in the "best of" section on this board.
http://www.moparts.org/Tech/Archive/bigblock.html
Re: Stroker 400? [Re: Dodgem] #701104
05/18/10 07:39 PM
05/18/10 07:39 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Another thing to consider is the 400/451 stroker may run a couple tenths quicker than an identically built 440 due to less reciprocating weight, e.g., shaved crank, and lighter pistons.
So it might appear that the extra cost to machine/clearance the crank pays for itself in the long run.
Re: Stroker 400? [Re: CompSyn] #701105
05/18/10 08:06 PM
05/18/10 08:06 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
If seeking a junkyard combo, the origins of the 451 build, are that guys were putting a 440 crank in a 400 with the stock slugs and rods for a cheapo race combo.
Do the math. stroke difference is 3.75-3.380= .370 half of that is .185 The slug is about .1 in the hole already, so with the 440 crank, it sticks out .085. Use a .040 gasket, and your down to .045. Should work with open heads, but you'd have to cut valve reliefs in the slugs I'm sure.. Obviously any ridge in the cylinders would have to be removed.
Obviously this would be a frankenstien motor of sorts, with little precision. Just pointing out the thinking behind it, and how being resourcefull could yield you a fairly powerful motor with little money in parts. 11:1 bigblock out of junkyard stuff.
Back to the modern world... Stroker kits make the cost of building a 500" motor about the same as building a 451, so it would seem obvious that bigger is better.
Re: Stroker 400? [Re: 76dodgeboy] #701106
05/18/10 08:53 PM
05/18/10 08:53 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
My buddy has a 451 and runs 12.3's in a 70 charger without alot of other work. With a better converter and heads He could run sub 12's
I have a 440 stroked and bored to 498 in My 67 plymouth and are looking at sub 12's.....hopefully
Re: Stroker 400? [Re: terzmo] #701107
05/18/10 09:02 PM
05/18/10 09:02 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
read the 451 manifesto
http://www.arengineering.com/articles/451.html
Get the book by Andy F
How to Build Max-Performance Mopar Big Blocks by Andy Finkbeiner
It's better to spend a little on research before buying parts.
Re: Stroker 400? [Re: RodStRace] #701108
05/18/10 09:20 PM
05/18/10 09:20 PM
Iowa
Iowa
I have the 400 block already aswell as a Complete 440. I also have closed chamber heads I could use
Re: Stroker 400? [Re: dave571] #701109
05/18/10 09:23 PM
05/18/10 09:23 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Obviously this would be a Frankenstein motor of sorts, with little precision. Just pointing out the thinking behind it, and how being resourcefull could yield you a fairly powerful motor with little money in parts. 11:1 bigblock out of junkyard stuff.
Junkyard combo... Frankenstein motor... Little precision... Anything but. Look, the 400/451 stroker build is one of the most popular builds today, period! That's why many of the piston manufactures make off-the-shelf pistons for this combo.
Consider results of the 2009 Amsoil/Mopar Muscle Magazine Engine Challenge. All seven participants utilized 400 blocks ranging in size from 451 to 512 cubic inches. Further, all were required to use Edelbrock RPM heads.
This engine challenge factors in power, torque, and cost of the build. The 500-inch strokers in the challenge did not come out on top because even though they produced more torque, they were MORE COSTLY TO BUILD.
The winner of the challenge was Schurbon Engine and Machine with their 451ci, 582HP, 544lb/ft engine. They used a factory 400 block, factory forged 440 crank, and factory 440 connecting rods with Keith Black #280 pistons.
You can watch this winning 400/451 combo spin on the dyno in this video by clicking HERE
By the way, all the 451-inch based engines used factory 400 blocks and factory forged 440 crankshafts. In addition, this budget based combo took 1st, 2nd, 3rd and 4th in the challenge with the 500-inch strokers rounding out the last three spots due to the cost to build. Also notice that the 451 combos made more horsepower than the 500-inch builds, but just a little shorter on torque.
Check out the results of the 2009 Amsoil/Mopar Engine Challenge below:
1st) Schurbon Engine and Machine - 452ci, 582HP, 544lb/ft
2nd) Chenoweth Speed And Machine - 452ci, 589HP, 518lb/ft
3rd) Laroy Engines - 452ci, 726HP, 568lb/ft
4th) Promax Performance - 451ci, 568HP, 518lb/ft
5th) Mid America Racing Engines - 500ci, 697HP, 619lb/ft
6th) JD Engine and Machine - 499ci, 724HP, 610lb/ft
7th) R.M. Competition - 512ci, 628HP, 596lb/ft
So as we can see, some of the top Mopar builders in the country have proved that a budget based 400/451 stroker combo can perform quite well and do it reliably.
If you have the cash and want to build a 500-inch motor with aftermarket parts, that's fine, but don't be surprised when a 400/451 motor with old "junkyard" Made In America Chrysler parts provides as good as or better performance.
Re: Stroker 400? [Re: CompSyn] #701110
05/18/10 09:42 PM
05/18/10 09:42 PM
dave571 Offline
dave571  Offline
If you reread my post, I am referring to the origin of this build. It DEFINATELY was a frankenstien, little precision, junkyard combo, to get a cheap 11:1 440 plus cid motor, for nothing more than turning down a crank, and slapping it all together. Ignore the balance issues, and give'r.
The modern 451 that guys build, with the right quality pistons, etc.. is a great build.
I will restate, that with the cost's of modern stroker kits being quite reasonable, I think it makes more sense to build a bigger motor, for the same money as what the 451 will cost in the end.
Re: Stroker 400? [Re: dave571] #701111
05/19/10 03:18 AM
05/19/10 03:18 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Awesome! Looks like we’ve brought the story full circle. From the meager beginnings as a non-precision-junkyard-frankenstein motor to an all out 726 horsepower screamer.
I’m not sure where you’re coming up with your math, but I estimate that if I had to start from scratch and acquire all the parts and machine work for a balanced reciprocating assembly like the one used in Schurbon Engine and Machine’s 582HP, 544lb/ft - 400/451 stroker build, I’d be looking at around $1,400.00 give or take a few pennies. The thing is there’s many who have a lot of the parts sitting around anyway, like the original poster here, and don’t have purchase everything from scratch. That in of itself makes the old 400/451 build a good value.
Now if one is going to buy a 500-inch stroker kit they’re looking at upwards of:
Muscle Motors - 400/511 stroker kit $2099.00
440Source - 400/512 stroker kit $1897.00
Indy Cylinder head - 400/500 stroker kit $2150.00
Pricing above does not include the possible/probable extra machine involved to correct the questionable tolerance of aftermarket crankshafts that are produced offshore. And some have indicated the aftermarket connecting rods have some tendencies of requiring resizing as well.
Guess it’s all in what one wants…
Re: Stroker 400? [Re: CompSyn] #701112
05/19/10 03:48 AM
05/19/10 03:48 AM
Port Alberni, British Columbia
MoparDonny Offline
MoparDonny  Offline
My 440 crank, by the time I had it cut and then everything balanced to it(or vice versa) cost me 400 bucks. My combo is a deadly little street motor but I have 440 LY (good stock stuff)rods in it that I had hones for full floating pins, Expensive JE pistons with a tiny 1.31 compression height. I think that my Align honing, Cam bearing install, Bore, deck, clean, rod resize and mentioned crank work, came out to $1400. Add $1200 worth of JE pistons/pins/rings, she gets pricey for low budget. 1500 for heads, 1000 for miscellaneous stuff ( water pumps, studs, cam, heavy duty rocker shafts,rockers, widage tray, oil pump, timing set, gaskets .
Goes like a raped date, but don't expect it to be all that cheap if you plan on using some good aftermarket stuff on it. That 440 might be the way to go on the cheap. I put together a 12 second 440 with nothing more than a 509 cam , headers, and home ported 452 heads I think it was a 1500 dollar build.
Re: Stroker 400? [Re: MoparDonny] #701113
05/19/10 09:20 AM
05/19/10 09:20 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
I think that my Align honing, Cam bearing install, Bore, deck, clean, rod resize and mentioned crank work, came out to $1400. Add $1200 worth of JE pistons/pins/rings, she gets pricey for low budget. 1500 for heads, 1000 for miscellaneous stuff (water pumps, studs, cam, heavy duty rocker shafts,rockers, widage tray, oil pump, timing set, gaskets.
We are not disagreeing per say, but you've missed the point. What we are talking about is a side-by-side comparison of a balanced reciprocating assembly, budget 400/451 vs. 400/511(aftermarket stroker kit).
Reciprocating assembly meaning crank, rods, pistons, pins, locks, main bearings, rod bearings, and piston rings. (all the components that are generally included in a aftermarket stroker kit)
So if one rounds up the "good stock stuff", the forged 440 crankshaft, LY rods along with decent aftermatket parts, like Schurbon Engine and Machine's 582HP, 544lb/ft - 400/451 stroker build as shown in THIS VIDEO, you're looking at around $1,400.00 give or take.
That's about $600.00 less than purchasing an aftermarket stroker kit; money in which you use to purchase water pumps, studs, cam, heavy duty rocker shafts,rockers, widage tray, oil pump, timing set, gaskets, etc, etc, etc...
I'm not talking about buying top high dollar components for a no holds bared build, I'm talking about value-per-dollar return that's hard to beat with an economical tried and true 400/451 build as proven by the 2009 Amsoil/Mopar Engine Challenge.
In some cases, less is more...
Re: Stroker 400? [Re: CompSyn] #701114
05/19/10 12:40 PM
05/19/10 12:40 PM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
I'm not any means an expert, but I think from looking at the engine challenge that the ~$600 more is not a bad deal for the useable increase in torque across the board with the bigger engines. At least in a heavy car.
Re: Stroker 400? [Re: Jeff_383] #701115
05/19/10 08:23 PM
05/19/10 08:23 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I cant't think of anything i can do to an engine for $600( not counting nitrous)that will improve the performance as much as an additional 50 cubes will.
Re: Stroker 400? [Re: forphorty] #701116
05/19/10 11:04 PM
05/19/10 11:04 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
That's why I built mine. 493 500 horse 600 ft/lb on regular gas with no drama. I don't know how you build a 451 stroker for $1400. Costs more than that for real machine work. Pressure wash and paintbomb builder maybe but you ain't winning no trophy with that setup.
Kevin
Re: Stroker 400? [Re: Twostick] #701117
05/20/10 12:47 AM
05/20/10 12:47 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I just got done assembling my 452 (.040 over). I kept track of every penny, and came in just under $5000-. But I was able to re-use some parts off my 383. Can't wait to hear this baby run
I'll agree with the $600 number as well. That's an accurate budget # between building a 3.38 stroke 400 vs. a 3.75 stroke. Nothing else you could do with that money will yield the same results.
Re: Stroker 400? [Re: forphorty] #701118
05/20/10 12:48 AM
05/20/10 12:48 AM
dave571 Offline
dave571  Offline
That is the math I'm using.
for 600 bucks more, bigger is better.
