Re: Almost done, but now no back up lights on my 73 Charger
[Re: wh23g3g]
#701040
05/18/10 12:52 AM
05/18/10 12:52 AM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
quick check, if you have it, is to peek the owners manual, and see if it describes a "key reminder' for a buzzer. it would be in the book, if you have it.
[Re: wh23g3g]
#701045
05/18/10 01:00 PM
05/18/10 01:00 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Assuming of course, since the car is 37 years old you checked the bulbs.
The ground on the reverse lights is just the housing. If you look at the plug it is a single wire. You can check for voltage here in reverse. If you have voltage, it is a ground issue.
If I remember correctly the reverse harness is just two wires at the bulkhead, see picture, this is a older RR but should be similar.
It should be plugged into a something and leading to the transmission reverse switch. On this picture it is not.
If it is plugged in, unplug it and jump the two wires together as it is a little easier than crawling under the car. Check to see if the reverse lights are on. If 'on' you most likely have a bad reverse (NSS) switch. If unplugged well you know it is not plugged in and that your problem.
If not on check to see if one of the two wires has 12 volts. If no then the fuse is most likely blown.
If you get battery voltage you have a issue with the wire going to the reverse lights. The white with black tracer before the rear harness plug and violet from the harness plug to the reverse light.
Of course all of these test are done with the ignition switch in the 'on' position.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: stumpy]
#701048
05/18/10 01:48 PM
05/18/10 01:48 PM
Posts: 715 Tulsa, Oklahoma
Charger_440
Tulsa, Oklahoma
even if the adjustment was off, the backup lights should still come on (though maybe not in reverse) as he moved the lever down through the gears...at the point where it hits that contact, the lights would come on. so adjustment should be ok. and if the car doesnt start in gear, you know the switch is ok, then youres back to tracking power and ground.
In a conversation with a Wyoming State Patrolman... "A 318 ??!!! But I clocked you at 142 mph!!!"
[Re: stumpy]
#701050
05/18/10 02:08 PM
05/18/10 02:08 PM
Posts: 3,426 weymouth,mass.
meepmeep70
weymouth,mass.
could be worse,my back up lights come on in reverse and come on and stay on when i shift into drive ,try doing like said with a simple test light car in reverse,key on,check to see if there is any power there,your plate light is in the same harness,does that work?
[Re: meepmeep70]
#701051
05/18/10 02:24 PM
05/18/10 02:24 PM
Charger_440
Tulsa, Oklahoma
stumpy youre right, he didnt, i guess i took for granted that they would have done that, lol. didnt mean to step on toes. B.
[Re: wh23g3g]
#701055
05/18/10 11:39 PM
05/18/10 11:39 PM
Posts: 7,759 So Cal
HealthServices
So Cal
According to the wire diagram for the 73 charger it one is black and the other is black with a tracer. meaning black wire with a white line.
It should be the only pig tail sticking out of the bulkhead, like what is in the picture. the connector has two wires going to it.
If you follow one end down, it will go down to the transmission.
Since yours is a automatic there will be one wire sticking out and going to the starter relay
Allen
[Re: HealthServices]
#701056
05/18/10 11:46 PM
05/18/10 11:46 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Sorry I only have pictures of earlier models with manual transmission but the connector is the same and the connector you jump is the one leading to the bulkhead not the transmission side.
If you take a good quality picture of you bulkhead connector I will point it out for you.
At least I should be able to.
Allen
[Re: wh23g3g]
#701058
05/20/10 01:29 AM
05/20/10 01:29 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
since 71, the NSS has its own plug arriving DIRECTLY to bulkhead conector on Bs and Es, none intermediate plug arriving to another harness like on earliers or A bodies
three wires on them ( a 4th wire directly to bulkhead plug when AC car )... two blacks to drive reverse light ( one traced ) and one brown traced yellow ( Neutral ground ). Since 72, the brown traced got a spliced signal to inside the cab to drive the seatbelts warning signal ( relay or interlock )
one of the blacks is allways powered with Key in RUN or ACC... gets the NSS and when gearing revers this closes the circuit to energize the other black wire up to rear harness.
On back of bulkhead ( inside the cab ) these wires are white and white traced, not black, but more of the same, one enregized allways with key, and the other one just when geared in R, then arriving to kick panel plug, where becomes on violet wire up to rear lights.
You can simply unplug the NSS harness from bulkhead and jump the cavities where black wires arrives, Put the key in ACC and check the reverse lights, If they turn on, problem is at harness or NSS ( or rostercomb inside the tranny as the biggest problem )
Plug it back, and now check at NSS plug underneath the car, jump both outer terminals at NSS plug... same, they must turn on reverse light. If they do, then is NSS or rostercomb.
