Need detail pics of Challenger hood pin setup #700874
05/17/10 09:42 PM
05/17/10 09:42 PM
541 slobovia
A990 Offline OP
A990  Offline OP
541 slobovia
I'm installing a set on a 70 Challenger and want to get it close as possible. I'm not sure if I'm dealing with an original hood pin hood, or if its been drilled before. Also need to know how the screws are oriented on the plates, where the lanyards attach, and whether the clips are N/S or E/W
Thanks in advance
Ken
Re: Need detail pics of Challenger hood pin setup [Re: A990] #700875
05/17/10 10:38 PM
05/17/10 10:38 PM
United States
V
v269 Offline
v269  Offline
V
United States
under hood
Re: Need detail pics of Challenger hood pin setup [Re: A990] #700876
05/17/10 10:40 PM
05/17/10 10:40 PM
United States
V
v269 Offline
v269  Offline
V
United States
top side
Re: Need detail pics of Challenger hood pin setup [Re: v269] #700877
05/17/10 11:04 PM
05/17/10 11:04 PM
541 slobovia
A990 Offline OP
A990  Offline OP
541 slobovia
v269
On top view of the hoodpin setup, is the hoodpin post
dead center in the plate, or not? Thanks for the pics and btw VERY nice Challenger
Ken
Re: Need detail pics of Challenger hood pin setup [Re: A990] #700878
05/18/10 08:29 AM
05/18/10 08:29 AM
United States
V
v269 Offline
v269  Offline
V
United States
yes, if the hole is already punched in the hood and it's not centering i've gained movement with the pin by slightly enlarging the fender hole.there is a cut out in the underhood bracing for the hole if someone has cut it hopefully it's within that area, but if it's not that another set of problems.
