Re: swapping from power to manual brakes
[Re: Tommy383]
#700868
05/17/10 10:35 PM
05/17/10 10:35 PM
Posts: 10,212 Someplace you aren't
SomeCarGuy
In earlier 68-70 B bodies and E body cars, there is a metal plate that you need that will bolt to the firewall. Maybe somebody else will know for sure on your model car if that plate is needed.
On the cars listed, it is sort of a reducer that takes up the extra space that power brakes need.
I want my fair share
[Re: SomeCarGuy]
#700869
05/17/10 11:15 PM
05/17/10 11:15 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
Yes, that plate is needed. Otherwise, there will be a hole in the firewall for hot air to get into the cabin. It also provides a little extra rigidity to the firewall from all the flexing from brake pedal pressure (particularly with the pedal pressure required with manual brakes).
Did the same swap on my car - '72 RR.
