440 header bolt coolant leak..is it normal???? #700686
05/17/10 05:59 PM
05/17/10 05:59 PM
Ontario
speedracer4406 Offline OP
Ontario
The engine was rebuilt before I bought the car but not run in the car. The car is almost finished and I've run it several times without coolant and it fires right up. Once coolant was in the system, and it was running for a few minutes, I noticed a drip on the driver's side front header flange. When I removed the header bolt, coolant came rushing out. Is this normal??? Any help would be greatly appreciated. thanks.
Re: 440 header bolt coolant leak..is it normal???? [Re: speedracer4406] #700687
05/17/10 06:12 PM
05/17/10 06:12 PM
NY usa
540challenger Offline
NY usa
Relax al is normal Srock big block heads all the exhaust bolt hole go into the water jackets.
some ways to deal with this:
1. Use studs IF you can.
2. Bolts make sure there is penty of threads going in to the head use a sealant. I use arp thread sealent you can use teflon tape Silcone etc..
It works best If you drain the block to below the bolts holes and let the sealant dry over night.
Also if you every play with a small block on stock LA head only the 2 out bolts go into the water good luck and get her sealed up
Re: 440 header bolt coolant leak..is it normal???? [Re: 540challenger] #700688
05/17/10 06:19 PM
05/17/10 06:19 PM
Ontario
Ontario
Thanks. Will do it this evening. Is it possible that the water leaks into the oil from not having sealer on the header bolts??
Re: 440 header bolt coolant leak..is it normal???? [Re: speedracer4406] #700689
05/17/10 06:24 PM
05/17/10 06:24 PM
NY usa
NY usa
Not from the exhaust holes
Re: 440 header bolt coolant leak..is it normal???? [Re: speedracer4406] #700690
05/17/10 06:44 PM
05/17/10 06:44 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
If you have coolant in the oil you may want to re torque the heads and
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: 440 header bolt coolant leak..is it normal???? [Re: speedracer4406] #700691
05/17/10 06:53 PM
05/17/10 06:53 PM
Sebring, Florida
Mopar Grandpa Offline
Sebring, Florida
[ When I removed the header bolt, coolant came rushing out. Is this normal???
This is VERY normal. Just add some Bars Leak, or similar product, in the radiator and your leak is fixed, just follow the directions. ABSOLUTELY no need to do anything else. I've done this on every Mopar engine I've rebuilt and the leak stops.
