Front-end rebuild #700575
05/17/10 04:27 PM
05/17/10 04:27 PM
GTXtacy, IL
MarPar Offline OP
MarPar  Offline OP
GTXtacy, IL
Hi Guys!! I'm new to MoParts, and have been lurking around for a couple of days...HUGE forum!! Good stuff!!!
Anyway, i was wondering what would be a good, complete front suspension rebuild kit for a 68 GTX. Not that money is no object, but i would be willing to pay for top-quality stuff! I've seen A LOT of different companies offering a bunch of different packages (poly graphite, poly urethane) I want to change everything except the CA's and bushings (that will come later with disk brakes and drop-spindles). Torsion bars and bushings, sway bar mounts, ball joints and all the bushings i can... any comments are appreciated
-Mar
68 GTX 440cid 727 3.91SG 08 E-92 In God we trust...all others must pay cash
Re: Front-end rebuild [Re: MarPar] #700576
05/17/10 04:45 PM
05/17/10 04:45 PM
Northern OH
rapom Online content
rapom  Online Content
Northern OH
Espo is what I use and they are your cheapest source that carries only USA sourced parts that I know of.
Mancini Racing is also a good source. They only carry MOOG parts.
Re: Front-end rebuild [Re: MarPar] #700577
05/17/10 05:00 PM
05/17/10 05:00 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
Stay away from urethane lower control arm bushings on the street.
Re: Front-end rebuild [Re: boydsdodge] #700578
05/17/10 05:05 PM
05/17/10 05:05 PM
GTXtacy, IL
MarPar Offline OP
MarPar  Offline OP
GTXtacy, IL
Any specific reason? it is a street car, with a couple flogs at the track a year...thanks
Re: Front-end rebuild [Re: MarPar] #700579
05/17/10 06:48 PM
05/17/10 06:48 PM
Sebring, Florida
Mopar Grandpa Offline
Sebring, Florida
Stay with the original replacement type rubber. I put polyurethane in my Road Runner and it squeaked like crazy and rode like a log wagon. Removed it all and went back to the rubber.
Re: Front-end rebuild [Re: Mopar Grandpa] #700580
05/18/10 01:10 PM
05/18/10 01:10 PM
Maryland, USA,
satgtx Offline
satgtx  Offline
Maryland, USA,
ESPO great folks to work with.
Re: Front-end rebuild [Re: satgtx] #700581
05/18/10 01:17 PM
05/18/10 01:17 PM
Los Angeles, CA
JF_Moparts Offline
JF_Moparts  Offline
Los Angeles, CA
I've always been a fan of PST's rebuild kits. I've used three of them on my own cars. I go all Polygraphite, and I havent's experienced much (or any) squeeking, but the ride is solid. You will feel every bump. Then again, you stay straighter in the hard turns.
If you do go poly, I'd recommend the following:
Torsion bars of at least 170 lbs/in. (Stock is about 90-110)
Front sway bar - 1 1/8 or larger.
Welded frame connectors.
Good shocks.
Of course, the list goes on and on from there...
Re: Front-end rebuild [Re: JF_Moparts] #700582
05/18/10 02:13 PM
05/18/10 02:13 PM
GTXtacy, IL
MarPar Offline OP
MarPar  Offline OP
GTXtacy, IL
Good shocks.
Thanks Jim! Right now I have a stock sway bar and .096? (stock HD's) Torsion bars. I really don't want to cut or weld anything on her, i want more of a stockish setup that's a little tighter on turns. I know she's not going to handle like she's on rails, but just a little upgrade is what i'm looking for. I'm going to get new shocks and leaf springs also, any thoughts on them? Re: polygraphite, how solid of a ride are talking about?? like a filling rattling ride??
Thanks -Mar
Re: Front-end rebuild [Re: MarPar] #700583
05/18/10 02:18 PM
05/18/10 02:18 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Think about buying and replacing the dust boots with poly as the rubber ones everyone has been making for dust boots are crapola, or will be in a very short time. I think they make black ones so they won't attract attention.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Front-end rebuild [Re: MarPar] #700584
05/18/10 07:16 PM
05/18/10 07:16 PM
Los Angeles, CA
JF_Moparts Offline
JF_Moparts  Offline
Los Angeles, CA
Good shocks.
Thanks -Mar
I can't comment on the harshness of the ride with just the poly bushings, because when I've rebuilt my front suspensions, I also replaced the torsion bars and shocks with much firmer components. When I hit a pothole in my Sebring, I feel it! (I also have 40 profile tires, 205 lbs/inch torsion bars, and a slightly lowered front)
I did replace the rear suspension on my 71 Sebring and went with poly. That squeeked for the first year but since then has been quiet. I also got rid of the stock leaves and installed the Hemi 6 / 5+2 leaves. They're about 160 lbs/inch, and they work well with a rebuilt front.
If you want it mostly stock, I'd probably stick with rubber bushings and upgrade the anti-sway bar. I think the amount of lean in the older stock cars was their big handling downfall.
ps - I'm not an engineer, I've just read a bunch of books on automotive suspension design. I think upgrading a sway bar without upgrading the rest of the front is ok, but you might want to confirm that with an engineer.
Re: Front-end rebuild [Re: JF_Moparts] #700585
05/20/10 11:49 AM
05/20/10 11:49 AM
GTXtacy, IL
MarPar Offline OP
MarPar  Offline OP
GTXtacy, IL
So after doin some research, and thanks to the fine gentlemen who responded on this thread, i've come up with my parts list...see what y'all think.
QA1 shocks
XHD rear leafs
.10 T-bars
and this front-end kit...
http://www.billrolikenterprises.com/proddetail.asp?prod=205
couple questions though...
should i go with the 11/16" tie rod ends with that package? it says heavy-duty, and everything else is heavy-duty on the car..
Am I missing anything??
All comments are much appreciated!!!
-Mar
Re: Front-end rebuild [Re: MarPar] #700586
05/20/10 01:36 PM
05/20/10 01:36 PM
Los Angeles, CA
JF_Moparts Offline
JF_Moparts  Offline
Los Angeles, CA
Do you mean 1.10" torsion bars? If so, those seem kinda harsh. What's that, like 270 lbs/inch?
I run 205 lbs/inch with a small block and it's pretty firm.
Re: Front-end rebuild [Re: MarPar] #700587
05/20/10 03:16 PM
05/20/10 03:16 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
.10 T-bars
I too am unclear on the size of T-bars you've selected.
As for the bigger TRE, opinions vary about whether the bigger ones provide sufficient benefit for the added cost/weight. Personally, I am in favor of them.
As for missing anything, how are your existing sway bar frame bushings and end links?
Down to just a blue car now.
Re: Front-end rebuild [Re: JF_Moparts] #700588
05/20/10 03:16 PM
05/20/10 03:16 PM
GTXtacy, IL
MarPar Offline OP
MarPar  Offline OP
GTXtacy, IL
I can't remember where i saw it, but it thought i saw 180 lbs/inch for a those T-bars. i have .096 now, i wanted to go one step-up. I thought it was .10?? not sure tho!!!
Re: Front-end rebuild [Re: MarPar] #700589
05/20/10 03:17 PM
05/20/10 03:17 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
You've got the decimal in the wrong place.
.96"
1.0"
It's the diameter of the bar.
Re: Front-end rebuild [Re: MarPar] #700590
05/20/10 03:19 PM
05/20/10 03:19 PM
CA
mojavered Offline
mojavered  Offline
CA
You probably mean 1.0".
71 Challenger RT
440 / 727 / 8.75
Re: Front-end rebuild [Re: 68HemiB] #700591
05/20/10 03:21 PM
05/20/10 03:21 PM
GTXtacy, IL
MarPar Offline OP
MarPar  Offline OP
GTXtacy, IL
.10 T-bars
Ah yes!! i knew i forgot something!!
the sway bar bushings!! doesn't look like they are included in that set!! nor are the end links
guess i'll keep looking!!
Re: Front-end rebuild [Re: 68HemiB] #700592
05/20/10 03:22 PM
05/20/10 03:22 PM
GTXtacy, IL
MarPar Offline OP
MarPar  Offline OP
GTXtacy, IL
.96"
1.0"
Ah! ok thanks for the correction!
so yes, 1" T-bars is what i'm thinking...
Re: Front-end rebuild [Re: MarPar] #700593
05/20/10 03:29 PM
05/20/10 03:29 PM
GTXtacy, IL
MarPar Offline OP
MarPar  Offline OP
GTXtacy, IL
How bout this kit?? it's got pretty much everything i want...except that it's poly and not rubber bushings i know it's pretty far away from the stock set i was looking at, but it looks like it would be pretty bad-ass...
http://www.justsuspension.com/the-works-kit-for-mopar.html
Re: Front-end rebuild [Re: JF_Moparts] #700594
05/20/10 03:44 PM
05/20/10 03:44 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I think I'm going to try these in the shorter A-body length T-bars (stiffer) and see what happens. The worst I could do is crack the car in half.
