ignition issue? ballast resistor hot. #700517
05/17/10 03:05 PM
05/17/10 03:05 PM
Minnesota
Shaggy Offline OP
Shaggy  Offline OP
Minnesota
1978 dodge truck 4 pin ballast. Been parked 4-5 years, but was my daily driver before this. Got it running again, but it seems to be cooking the ballast resistor. It will restart fine again if left to cool off. Amp gauge is reading high so I think it might be overcharging??? Will a bad voltage regulator cause this?
1969 Dart
Re: ignition issue? ballast resistor hot. [Re: Shaggy] #700518
05/17/10 03:06 PM
05/17/10 03:06 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Don't understand the question is the truck not starting or are you worried the resister is getting hot?
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: ignition issue? ballast resistor hot. [Re: Shaggy] #700519
05/17/10 03:10 PM
05/17/10 03:10 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
If the charging system has a problem of high output voltage, then the ballast resistor will run very hot.. Eventually it will burn itself up because its resistance increases as it heats up forcing it to absorb more voltage...
Just my $0.01..
Re: ignition issue? ballast resistor hot. [Re: Sinitro] #700520
05/17/10 03:21 PM
05/17/10 03:21 PM
Might slow charge the battery on a charger overnight
Re: ignition issue? ballast resistor hot. [Re: RapidRobert] #700521
05/17/10 03:24 PM
05/17/10 03:24 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Ballast resisters run hot. You don't want to touch one at an time. New they will smoke. Ballast resister should have nothing to do with the rate of charge.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: ignition issue? ballast resistor hot. [Re: MoparforLife] #700522
05/17/10 03:37 PM
05/17/10 03:37 PM
Minnesota
Shaggy Offline OP
Shaggy  Offline OP
Minnesota
It will start and run when it's cold/first started. But if run for awhile then shut off it won't restart and it acts like a bad ballast as it fires once after cranking over and then the key is released due to no start. Starts fine again after cooling off for a bit. It's charging at 14.78 volts. Can the voltage regulator be tested?
Re: ignition issue? ballast resistor hot. [Re: RapidRobert] #700523
05/17/10 03:38 PM
05/17/10 03:38 PM
Minnesota
Shaggy Offline OP
Shaggy  Offline OP
Minnesota
Did that.
Re: ignition issue? ballast resistor hot. [Re: Shaggy] #700524
05/17/10 03:43 PM
05/17/10 03:43 PM
Upper Midwest
Upper Midwest
If it were the ballast it would not be intermittant like that. Once burnt out they are dead.
Are you sure that yo aren't boiling fuel out from the carb into the intake causing a flooding condition. Have you tried to start it holding the gas pedal to the floor to unload a flooded engine.
Coils can also have thermal breakdowns.
Re: ignition issue? ballast resistor hot. [Re: MoparforLife] #700525
05/17/10 03:53 PM
05/17/10 03:53 PM
When it's good & hot & acting up I'd have a helper turn the key to "start" with you under the hood checking voltages at the coil/ballast and do you have another good dist you could plug in at that point in time and spin it by hand to see if it's the pickup. yes charging the batt suggestion was not for the ballast but was for the bulkhead as to not aggravate things any further till you sort it out
Re: ignition issue? ballast resistor hot. [Re: MoparforLife] #700526
05/17/10 03:54 PM
05/17/10 03:54 PM
Minnesota
Shaggy Offline OP
Shaggy  Offline OP
Minnesota
Pulled the coil wire and just get the one spark when it won't start when the key is turned off.
I think this all started after I washed off some of the grime from sitting so long last night. Not under the hood though. Was working fine before that or so it seemed.
Re: ignition issue? ballast resistor hot. [Re: Shaggy] #700527
05/17/10 03:57 PM
05/17/10 03:57 PM
pulled the coil wire and just get the one spark when it won't start and the key is turned off.
Sounds like classic ballast issue sort of but the last time my old truck acted like that it was the ECU
Re: ignition issue? ballast resistor hot. [Re: RapidRobert] #700528
05/17/10 04:02 PM
05/17/10 04:02 PM
Upper Midwest
Upper Midwest
I agree Robert but cooling off wouldn't bring the ballast back to life. It could a coil, ECU, or pick up coil with thermal breakdown. But when the connection in a ballast is burnt off it is gone.
Re: ignition issue? ballast resistor hot. [Re: Shaggy] #700529
05/17/10 04:21 PM
05/17/10 04:21 PM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
Sounds like a bad ECU, or more likely a bad ground to the ECU. Rusted from sitting I bet.
I want my fair share
Re: ignition issue? ballast resistor hot. [Re: MoparforLife] #700530
05/17/10 04:25 PM
05/17/10 04:25 PM
Correct. Yeah I seem to have gotten distracted from the OP ballast Q from the getgo on this thread. One of those days
Re: ignition issue? ballast resistor hot. [Re: SomeCarGuy] #700531
05/17/10 04:31 PM
05/17/10 04:31 PM
Minnesota
Shaggy Offline OP
Shaggy  Offline OP
Minnesota
I had pulled the ecu and remounted in in case it had bad ground to fender. Swapped in a different voltage reg and now see a max of 14.02 volts at around 3000rpm. Thing is now it seems fine again. I pulled and cleaned up a few electrical connections too so.....I hope this issue don't come back!!!
Re: ignition issue? ballast resistor hot. [Re: Shaggy] #700532
05/17/10 04:51 PM
05/17/10 04:51 PM
Sounds like it was a bad ground.
Re: ignition issue? ballast resistor hot. [Re: SomeCarGuy] #700533
05/17/10 09:21 PM
05/17/10 09:21 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
It sounds to me like the resistor is in the circuit when trying to start which works somewhat ok when cold but not hot.
Re: ignition issue? ballast resistor hot. [Re: SomeCarGuy] #700534
05/17/10 10:16 PM
05/17/10 10:16 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Bad ground or other connection problem IF it stays gone now.
If not, it's just an intermittant component you haven't found yet.
Your previous(prior to the reg change) voltage readings were fine. You asked abouth testing the regulator. By reading the voltage with it running, that is what you did.
Changeing the regulator, to the one you have now, with the slightly lower reading, should not have affected anything. Not any good components anyway.
If it stays gone, it was a resisitance in a connection somewhere getting hot. If it comes back, ikt's a resistance in a component (pickup coil, ecu) doing the same thing.
Re: ignition issue? ballast resistor hot. [Re: dave571] #700535
05/18/10 07:16 PM
05/18/10 07:16 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I could very well be the ballast, it's called an intermittent OPEN. If there is an open in the resstance wire the ballast is made out of it will get larger as it heats up. It is entirely possible that, cold, the break touches fine, but as it heats up and thnigs expand the connection is lost and the enigine dies. Once it cools off it works, classic intermittent open behavior.
Easy test, jumper out the ballast and see if it runs then, pull the jumper and see if it dies again.
Don't be the exception.
