Re: Electrical gremlin
[Re: JM67RT]
#700311
05/17/10 07:43 PM
05/17/10 07:43 PM
Posts: 329 Orange Park, FL
MRHWS
Orange Park, FL
Had similar, dome & map lights flashed when signaled. I did 2 things, replaced 2 fuses that control signals and tighted the fuse box screws under the dash. 1 of the 2 fixed my problem.
Also, when braking, the tail lights would go out on the side I was signaling.
1973 Charger SE
1974 Charger Rallye 440 Aztec
2008 Charger SRT8
[Re: MRHWS]
#700312
05/18/10 01:09 AM
05/18/10 01:09 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
brake/hazzards FUSES are loosen from fuse HOLDERS, or they are corroed
BTDT exactly on same deal
when you have that fail, becarefull that fuse wilL be REEEALLY HOT able to melt the fuseblock. you can check it to confirm but with REEEAALLY CARE. IT WILL BE REALLY HOT!
