Timing Lights with MSD boxes - What do you use? #700117
05/16/10 11:01 PM
05/16/10 11:01 PM
United States
STLDuster Offline OP
United States
I am working on upgrading my ignition and am looking at the MSD 6AL-2.
The instructions say not to use a digital or dial back timing light. Seeing as the only timing light I have is a Craftsman Dial Back has been around since the dawn of time. It may be time for me to upgrade.
What do you guys use with you multi spark ignition?
"No great genius has ever existed without some touch of madness." - Aristotle
Re: Timing Lights with MSD boxes - What do you use? [Re: STLDuster] #700118
05/16/10 11:05 PM
05/16/10 11:05 PM
Connecticut
biginchmotor Offline
Connecticut
I bought the MSD timing light....John.
Re: Timing Lights with MSD boxes - What do you use? [Re: biginchmotor] #700119
05/16/10 11:11 PM
05/16/10 11:11 PM
United States
United States
I was looking at this one but I didn't know if it was worth that kind of price.
http://www.summitracing.com/parts/MSD-8992/
Re: Timing Lights with MSD boxes - What do you use? [Re: STLDuster] #700120
05/17/10 12:24 AM
05/17/10 12:24 AM
Cab_Burge Online work
Cab_Burge  Online Work
I bougt a Flaming River brand single wire battery powered timing light to use on the MSD BTW, I have used non dial back Craftsman and the Penske brand non dial back when Sears carried them, burnt them rascals up using the the old 404c and 404B and agin on the first generation MSD7 non A and non AL2 I do have two older(ten yrs+)Craftsman dial back timing lights with the cords that unplug that have survived numerous uses on a MSD7C and a MSD 404C(Mopar factory ignition plugin compatable)
Post deleted by Defbob [Re: Cab_Burge] #700121
05/17/10 12:38 AM
05/17/10 12:38 AM
Re: Timing Lights with MSD boxes - What do you use? #700122
05/17/10 01:08 AM
05/17/10 01:08 AM
FRANCE / PARIS
NENE Offline
NENE  Offline
FRANCE / PARIS
I use a Snap On digital with dial back, do the job without any trouble, works for me on a MSD 7AL2.
'70 Cuda with a 572 Keith Black / B1 heads with a sheetmetal intake (2 dominators) Lencodrive 3 speed trans. 2350 lbs with me Run 8.04" / 168 mph 1.11" 60 ft Fastest Mopar at the Euro Mopar Nats website : http://vantastic-racing.com/
Re: Timing Lights with MSD boxes - What do you use? [Re: NENE] #700123
05/17/10 04:02 AM
05/17/10 04:02 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I have a dial back and non dial back craftsman...the dial back doesn't read right with the msd...but the regular one works great with my digital 6+.
Re: Timing Lights with MSD boxes - What do you use? [Re: Quicksilver440] #700124
05/17/10 06:16 AM
05/17/10 06:16 AM
Missouri
StrokerPost Offline
StrokerPost  Offline
Missouri
There was an article in one of the mags several years back about this. They tested numerous diff lights, some dialback, some non-dialback, and if I remember right, the el cheapo non-dialback light did the best. The dialback lights wouldnt stay steady for whatever reason, and I found that to be true with my Sears dialback light. Just used my Dad's old non-dialback after that.
Re: Timing Lights with MSD boxes - What do you use? [Re: StrokerPost] #700125
05/17/10 10:10 AM
05/17/10 10:10 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I use a Sears dial back with a MSD 6AL with no problems even check it back to back with a elcepo and got the exact same readings with both lights.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Timing Lights with MSD boxes - What do you use? #700126
05/17/10 10:28 AM
05/17/10 10:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Flaming River 40.00 uses two D cells and one wire on plug .no other wires needed
Same one here... best light I have used and I have a
few of them... MSD can be touchy due to its multi
spark under 3000 rpm.... plus the Flaming River uses
the 2 D-cell you dont need the power hook up which
is easier and faster
Re: Timing Lights with MSD boxes - What do you use? [Re: STLDuster] #700127
05/17/10 12:41 PM
05/17/10 12:41 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I think that light is made by Ferret Instruments. The Ferret 80 looks the same and has the same features, just not red. Google is your friend. http://www.google.com/search?hl=en&a...amp;safe=images
You will find it for less than $80. They also make several other models with or without dialback. Some have a tach built in. Some are rechargeable single wire units. The higher end models have red housings just like the MSD. The Ferret 80 is the cheapest, the others are obviously priceier.
Re: Timing Lights with MSD boxes - What do you use? [Re: GomangoCuda] #700128
05/17/10 04:26 PM
05/17/10 04:26 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
That light looks just like my Ferret from the 90s, still works great today.
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: Timing Lights with MSD boxes - What do you use? [Re: 65signet] #700129
05/17/10 05:36 PM
05/17/10 05:36 PM
Q
Quicktree Offline
Quicktree  Offline
Q
no problem here with my sears dial back light either. I bet a lot of other problems gets bliamed on the lights.
Re: Timing Lights with MSD boxes - What do you use? [Re: NENE] #700130
05/17/10 09:03 PM
05/17/10 09:03 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
me too.
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Timing Lights with MSD boxes - What do you use? [Re: Quicksilver440] #700131
05/17/10 09:24 PM
05/17/10 09:24 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Ditto for me.
Re: Timing Lights with MSD boxes - What do you use? [Re: 65signet] #700132
05/17/10 09:31 PM
05/17/10 09:31 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Flaming River...
Re: Timing Lights with MSD boxes - What do you use? [Re: Quicktree] #700133
05/17/10 09:34 PM
05/17/10 09:34 PM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
My same old sears one works well for it too! but.... now you got me paranoid. Maybe I'm running 55 degree total advance!
Mike
1969 Dodge Dart Swinger
Re: Timing Lights with MSD boxes - What do you use? [Re: MikeyT] #700134
05/17/10 10:03 PM
05/17/10 10:03 PM
Oconomowoc, WI.
Cudahlr Offline
Cudahlr  Offline
Oconomowoc, WI.
I have the 6-AL 2 programmable, and have used the craftsman dial back, craftsman non dial back, and the flaming river, they all read exactly the same.
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp
1985 Harley Sportster Bobber
2006 Ram 2500 sport - The Cudahlr
Re: Timing Lights with MSD boxes - What do you use? [Re: MikeyT] #700135
05/17/10 10:04 PM
05/17/10 10:04 PM
IN
ahy Offline
ahy  Offline
IN
The MSD drove my Sears dialback nuts. I got the battery powered flaming river and it works great.
Re: Timing Lights with MSD boxes - What do you use? [Re: ahy] #700136
05/17/10 10:42 PM
05/17/10 10:42 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
A friend of mine bought the most expensive one that AutoZone sells. That's what I use (I think I've had it in my possession longer than he has). In general, I don't know how good it is, but my MSD doesn't seem to mess it up at all. I should probably check it with known-good light just to make sure. But it runs well, I sent the initial with the vacuum method, and it seems to run just fine.
