Timing Lights with MSD boxes - What do you use?
#700117
05/16/10 11:01 PM
05/16/10 11:01 PM
Posts: 1,075 United States
STLDuster
United States
I am working on upgrading my ignition and am looking at the MSD 6AL-2. The instructions say not to use a digital or dial back timing light. Seeing as the only timing light I have is a Craftsman Dial Back has been around since the dawn of time. It may be time for me to upgrade. What do you guys use with you multi spark ignition?
"No great genius has ever existed without some touch of madness." - Aristotle
Re: Timing Lights with MSD boxes - What do you use?
[Re: STLDuster]
#700120
05/17/10 12:24 AM
05/17/10 12:24 AM
Posts: 43,163 Bend,OR USA
Cab_Burge
I bougt a Flaming River brand single wire battery powered timing light to use on the MSD BTW, I have used non dial back Craftsman and the Penske brand non dial back when Sears carried them, burnt them rascals up using the the old 404c and 404B and agin on the first generation MSD7 non A and non AL2 I do have two older(ten yrs+)Craftsman dial back timing lights with the cords that unplug that have survived numerous uses on a MSD7C and a MSD 404C(Mopar factory ignition plugin compatable)
Post deleted by Defbob
[Re: Cab_Burge]
#700121
05/17/10 12:38 AM
05/17/10 12:38 AM
#700122
05/17/10 01:08 AM
05/17/10 01:08 AM
Posts: 99 FRANCE / PARIS
NENE
FRANCE / PARIS
I use a Snap On digital with dial back, do the job without any trouble, works for me on a MSD 7AL2.
'70 Cuda with a 572 Keith Black / B1 heads with a sheetmetal intake (2 dominators) Lencodrive 3 speed trans. 2350 lbs with me
Run 8.04" / 168 mph 1.11" 60 ft
Fastest Mopar at the Euro Mopar Nats
website : http://vantastic-racing.com/
[Re: Quicksilver440]
#700124
05/17/10 06:16 AM
05/17/10 06:16 AM
Posts: 6,847 Missouri
StrokerPost
Missouri
I have a dial back and non dial back craftsman...the dial back doesn't read right with the msd...but the regular one works great with my digital 6+.
There was an article in one of the mags several years back about this. They tested numerous diff lights, some dialback, some non-dialback, and if I remember right, the el cheapo non-dialback light did the best. The dialback lights wouldnt stay steady for whatever reason, and I found that to be true with my Sears dialback light. Just used my Dad's old non-dialback after that.
[Re: StrokerPost]
#700125
05/17/10 10:10 AM
05/17/10 10:10 AM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I use a Sears dial back with a MSD 6AL with no problems even check it back to back with a elcepo and got the exact same readings with both lights.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
#700126
05/17/10 10:28 AM
05/17/10 10:28 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Flaming River 40.00 uses two D cells and one wire on plug .no other wires needed
Same one here... best light I have used and I have a few of them... MSD can be touchy due to its multi spark under 3000 rpm.... plus the Flaming River uses the 2 D-cell you dont need the power hook up which is easier and faster
#700131
05/17/10 09:24 PM
05/17/10 09:24 PM
Posts: 982 western pennsylvania
b1dartsport
Ditto for me.
[Re: MikeyT]
#700134
05/17/10 10:03 PM
05/17/10 10:03 PM
Posts: 465 Oconomowoc, WI.
Cudahlr
Oconomowoc, WI.
I have the 6-AL 2 programmable, and have used the craftsman dial back, craftsman non dial back, and the flaming river, they all read exactly the same.
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp 1985 Harley Sportster Bobber 2006 Ram 2500 sport - The Cudahlr
#700138
05/18/10 12:02 AM
05/18/10 12:02 AM
Posts: 778 Sherwood park, Alberta.
go green
Same here.. I have seen more people get all piled up on those dial back pieces of crap.
Plug fires .... light goes on ... look at balancer ...done
[Re: go green]
#700139
05/18/10 12:49 AM
05/18/10 12:49 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
I use a snap-on dial back and a mac tools dial back. Both work fine as long as i power them from a jump box. Hook them to the car and they go batty.
BB, TT5,Procharged 3300lb Street Car 4.79/154
