Re: w2 spark plugs
[Re: all spooled up]
#700049
05/16/10 09:54 PM
05/16/10 09:54 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Autolite AR 52 or AR-53. Try, and, read plugs ,should be close.
If you like drag racing, support your local track.
Re: w2 spark plugs
#700051
05/16/10 11:09 PM
05/16/10 11:09 PM
Posts: 43,242 Bend,OR USA
Cab_Burge
That 65 is probally a little hot for the compression ratio, try a 64 or 54 Or as already recommended the 3922 also That is a 5/8 body plug so don't be suprised if you buy a set. I like the Champion RN9YC or RC9YC (5/8 body)for those heads with that compression also
Re: w2 spark plugs
[Re: topside]
#700055
05/18/10 04:12 PM
05/18/10 04:12 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Been using Champion C59Y or YCs for years. C57 colder, C61 hotter. 5/8 hex. 13:1 368" W2 drag motor.
Same here... 59Y
