Wilwood Disc brake questions.. please help. #69972
06/08/08 03:37 PM
06/08/08 03:37 PM
Lafayette, IN
challengerman71 Offline OP
super street
super street
Lafayette, IN
Will a Wilwood front disc set up fit on a Master Power brakes spindle? i bought the master power brakes conversion 7 years ago, and it has worn a grove or two in my rotors.. they are not adjustable, so making the switch to quality.. Wilwood send the hub but no spindle.. just want to make sure it will work right and not screw anything up.
Re: Wilwood Disc brake questions.. please help. [Re: challengerman71] #69973
06/09/08 12:51 AM
06/09/08 12:51 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Make sure you have the correct kit, you did not mention if it's a drum or disc spindle -
http://www.wilwood.com/PDF/ds176.pdf
http://www.wilwood.com/PDF/ds180.pdf
The complete list -
http://www.wilwood.com/BrakeKits/Pages/08/index.asp
I would contact Wilwood if you're still unclear -
http://www.wilwood.com/Centers/Information/pages/contact.asp
Re: Wilwood Disc brake questions.. please help. [Re: Lefty] #69974
06/09/08 09:07 AM
06/09/08 09:07 AM
Lafayette, IN
super street
super street
Lafayette, IN
The complete list -
when i put the master power brake set up on.. it came with spindles.. they are front discs.. But i know they were based off of another mopar.. will that make a difference?
