70 CHARGER QUARTER WINDOW PROBLEM.... #699716
05/16/10 05:38 PM
05/16/10 05:38 PM
Ontario
speedracer4406 Offline OP
Ontario
After installing all the parts on my 70 Charger for the quarter windows, they both sit 1 inch too far back from the door glass. I've looked at all possibilities but can't see the solution. I've compared the parts to whats on ebay and they appear the same. the glass is new from AMD. Has anyone encountered this problem before and what is the solution? Thanks for any assistance.
Re: 70 CHARGER QUARTER WINDOW PROBLEM.... [Re: speedracer4406] #699717
05/16/10 09:03 PM
05/16/10 09:03 PM
United States
V
v269 Offline
v269  Offline
V
United States
don't know if these will help but here are some shots of a 69.
Re: 70 CHARGER QUARTER WINDOW PROBLEM.... [Re: speedracer4406] #699718
05/16/10 09:05 PM
05/16/10 09:05 PM
United States
V
v269 Offline
v269  Offline
V
United States
another
Re: 70 CHARGER QUARTER WINDOW PROBLEM.... [Re: speedracer4406] #699719
05/16/10 09:23 PM
05/16/10 09:23 PM
Temple, Texas
scoutsr2 Offline
scoutsr2  Offline
Temple, Texas
took me quite a bit to get mine right. I pretty much had to losen everything and get the glass where I wanted it then snug it up a bit at a time...be patient and trust me the one slide you think does not matter or adjust is the one it will take to fix it...good luck.
Re: 70 CHARGER QUARTER WINDOW PROBLEM.... [Re: speedracer4406] #699720
05/16/10 09:26 PM
05/16/10 09:26 PM
United States
V
v269 Offline
v269  Offline
V
United States
is it down from the top also? if so there is an adjustable stop toward the front at the top, and a stop at the back.
Re: 70 CHARGER QUARTER WINDOW PROBLEM.... [Re: speedracer4406] #699721
05/16/10 10:17 PM
05/16/10 10:17 PM
ne
broncobra Offline
broncobra  Offline
ne
Just a hint, my 67 Coronet service manual shows in great detail all the adjustments, and what they will accomplish -in or out, up and down for each area you can possibly adjust. Good Luck!
Re: 70 CHARGER QUARTER WINDOW PROBLEM.... [Re: broncobra] #699722
05/17/10 08:41 AM
05/17/10 08:41 AM
Ontario
Ontario
Thanks for the info guys. As far as I can see in the pics above, I have the parts in the right place. but the Aluminum assembly in my car does sit too far back. I will work on it this morning and post an update. thanks.
Re: 70 CHARGER QUARTER WINDOW PROBLEM.... [Re: broncobra] #699723
05/17/10 10:02 AM
05/17/10 10:02 AM
Ontario
Ontario
I got it to work. The advice about loosening all the bolts and moving everything worked. Also removed the rear stopper and installed after the window was adjusted. saved me a bunch of time. thanks for all the great info and pics. i will be visiting this site more often. have a great day everyone!
Re: 70 CHARGER QUARTER WINDOW PROBLEM.... [Re: speedracer4406] #699724
05/17/10 05:30 PM
05/17/10 05:30 PM
Temple, Texas
scoutsr2 Offline
scoutsr2  Offline
Temple, Texas
Woo hoo! Only way I could figure it out. Good job!
