Re: Fusable Link Size, Cordoba
[Re: ahy]
#699525
05/16/10 11:07 PM
05/16/10 11:07 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
NAPA or an auto-electrical shop should have the fusible link. #12 should be about right.
I would say more like #14, Depending if it has relays upgrades attached at battery or not. If not, 14 should be enough. If yes ( what BTW is wrong on ammeter design cars ) #12 is better.
#16 were on 60 amps car as much
[Re: NachoRT74]
#699526
05/16/10 11:09 PM
05/16/10 11:09 PM
RapidRobert
get the NAPA mopar fusible link iirc it's a 16 ga but not sure & you're good.
