Fusable Link Size, Cordoba #699520
05/16/10 01:09 PM
05/16/10 01:09 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
I have a friend that is attempting to replace his fusable link on his cordoba with a traditonal in line aftermarket fuse. My questions what size of fuse should he run?? I have no idea what the factory inline fuse was rated for. Thanks!
Re: Fusable Link Size, Cordoba [Re: faud88] #699521
05/16/10 10:05 PM
05/16/10 10:05 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
that wont work,the fusable leak is designed to allow a brief spike, a regular fuse will not.
Re: Fusable Link Size, Cordoba [Re: 05dakota] #699522
05/16/10 10:16 PM
05/16/10 10:16 PM
IN
ahy Offline
ahy  Offline
IN
The alternator on a Cordoba is either 78 or 100 amps... a lot more than a regular fuse holder can handle.
NAPA or an auto-electrical shop should have the fusible link. #12 should be about right. Solder in a few inches, shrink wrap or tape and he's good to go as long as whetever blew it in the first place is fixed.
Re: Fusable Link Size, Cordoba [Re: ahy] #699523
05/16/10 10:29 PM
05/16/10 10:29 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
With a fuse everytime he hits the starter it will blow. Fusible links are there for a reason.
Re: Fusable Link Size, Cordoba [Re: stumpy] #699524
05/16/10 11:06 PM
05/16/10 11:06 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
eeehm, not... the starter motor power doesn't go by the fuse link... just the signal to activate the starter relay, which barelly sucks power.
Re: Fusable Link Size, Cordoba [Re: ahy] #699525
05/16/10 11:07 PM
05/16/10 11:07 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I would say more like #14, Depending if it has relays upgrades attached at battery or not. If not, 14 should be enough. If yes ( what BTW is wrong on ammeter design cars ) #12 is better.
#16 were on 60 amps car as much
Re: Fusable Link Size, Cordoba [Re: NachoRT74] #699526
05/16/10 11:09 PM
05/16/10 11:09 PM
get the NAPA mopar fusible link iirc it's a 16 ga but not sure & you're good.
Re: Fusable Link Size, Cordoba [Re: RapidRobert] #699527
05/16/10 11:22 PM
05/16/10 11:22 PM
Spokane,WA
Genuinejed Offline
Genuinejed  Offline
Spokane,WA
I'm sure it's not correct, but just replaced a buddies with a 30 amp fuseholder as a temp. fix and seems to be working okay. His ammeter is inop due to battery in trunk, so that maybe why it's still alive!
1968 Plymouth road runner 1968 Dodge Coronet 500 64 D200 Good, Fast, Cheap. Pick Two.
