Anything special to rebuild a Motorhome 727 ? #699436
05/16/10 11:45 AM
05/16/10 11:45 AM
Southern CA
Colin Frolick Offline OP
Southern CA
so, i have an opportunity to pick up a '78 motorhome with a 440 and a "bad transmission". supposedly it goes but slips, i haven't gotten all the details. this rig is free to me if i head up to nor cal and fix the trans.
my question is... will any rebuild kit and parts for a 1978-era torqueflite work in a motorhome model or are there any specific pieces i'd need. hoping for no broken hard parts and new clutches/bands/seals will fix it. i'm planning to head up there next weekend with tools in hand so any tips would be welcome.
thanks
Re: Anything special to rebuild a Motorhome 727 ? [Re: Colin Frolick] #699437
05/16/10 12:17 PM
05/16/10 12:17 PM
scratchnfotraction Offline
may be a short shaft with a bolt on yoke
but the same inside as any other 727...just not the out put shaft
I have a 78 440/short 727 also
good luck with it
Re: Anything special to rebuild a Motorhome 727 ? [Re: Colin Frolick] #699438
05/16/10 01:23 PM
05/16/10 01:23 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Some of the larger coaches had a parking brake drum on the end of the transmission. Don't worry if you run across something along those lines. It doesn't change anything inside.
- Stu Harmon
Re: Anything special to rebuild a Motorhome 727 ? [Re: scratchnfotraction] #699439
05/16/10 01:53 PM
05/16/10 01:53 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
good luck with it
With the exception of a different output shaft seal and of course the bearing..
Re: Anything special to rebuild a Motorhome 727 ? [Re: Colin Frolick] #699440
05/16/10 03:33 PM
05/16/10 03:33 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
CROSS yerr fingers .. it COULD BE as simple as toasted fluid and the filter is just glazed-over.
SEEN THAT a bunch of times over-the-years.
Re: Anything special to rebuild a Motorhome 727 ? [Re: Colin Frolick] #699441
05/16/10 03:44 PM
05/16/10 03:44 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I got one out of a friends motor home 440 and tranny and it had the short output with U joint. I found a output shaft and tail stock and it is now in a friends gasser.
And I just got another one (440 and 727)out of a 78 motor home
and it is standard non lock up regular output 727 fluid is fine so?? anyway the rebuild kit for I think 71 and up.
some guys use the stronger short shaft running a u joint at the front and a truck like slip drive shaft. at the rear U joint
they say it's much stronger??
Re: Anything special to rebuild a Motorhome 727 ? [Re: Dodgem] #699442
05/16/10 07:45 PM
05/16/10 07:45 PM
on stronger
I ran a sb short shaft in my 68 Dart and have one in my 88 440 truck now
had a few in the club cab truck also
well cant realy say stronger,just they held up better to me
4500rpm N drops will get them all sooner or later
i also just added the CRT forward shift full manual valve body to the BB 727
the front 1/2 of the MH drive shaft is long enuff for my 88 short bed truck
cut it down 2" and add the spline/slip yoke to it
4" u-joint on one end and a 7290 on the other
