Re: Truck guys: cage question
[Re: TheOtherDodge]
#699354
05/16/10 05:09 PM
05/16/10 05:09 PM
Posts: 9,116 Falconer, NY
KatFysh
Falconer, NY
My down tubes came through right above the window. I actually cut into the rubber gasket. The rear bed cover was a hard cover that hung over the bed edges when new. I believe it was a Jason lid. I cut and cut and cut some more to get it to fit flush between the bedrails.. Looked good. I just never got to finish it.
When you decide to quit, THAT is the moment when you would've succeeded..
[Re: TheOtherDodge]
#699362
05/18/10 05:41 PM
05/18/10 05:41 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
based on the replies to this post, not that anyone cares, but I talked to the person doing the cage and it seems that they are running the bars from the middle of the main hoop through the cab below the rear window, through the bed parallel to the bed to where ever it mounts in the back. So the covers are not affected.
That is the way mine is,the bars go through the cab below the rear window and parallel with the bed. They are bolted to the main hoop and bolted to the frame above the rear end. You can unbolt the bars to remove the bed if needed. I have a cover on the bed.You can not see the down bars.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
