Need help-70 B body widow trim problem & question #699282
05/16/10 10:19 AM
05/16/10 10:19 AM
NY, Monroe County
70RRJim Offline OP
70RRJim  Offline OP
NY, Monroe County
I just put the glass in the car, polished the trim and now have a few problems
Front Trim - how do you install the corner trim clips and what do they do (see picute). A picture of this would be helpful for reference. I am assuming the hold down the side trim at the base and fill the corner.
Back Trim-- what a "pita", I polished and mounted but the corners are not holding down. At this point I think the moulding is bent or twisted. How should this normally be held down. A picture of this would be helpful for reference.
Trim Removal - now I have the trim in with all new clips,I think I have to remove back trim. Whats the trick without damaging the new clips for reuse.
thanks Moparts
Re: Need help-70 B body widow trim problem & question [Re: 70RRJim] #699283
05/16/10 11:46 AM
05/16/10 11:46 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Front corner trim hold downs screw into the A pillar on inside of door jam. Look for the small screw hole. The long end of hold down without screw hole slides inside end of trim. Do not have a photo. Good luck!
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
