Performer. Air Gap or LD340 Intake? #69893
06/08/08 12:43 PM
06/08/08 12:43 PM
NY
old340dog Offline OP
NY
Which would be better for a stock 340 rebuild with 8:5 -9:5 compression and stock cam? A performer, airgap or LD340. I'd like to switch manifolds on my rebuild. Also which carb would work best. I've heard allot of good about the Barry Grant carbs.
old340dog
Re: Performer. Air Gap or LD340 Intake? [Re: old340dog] #69894
06/08/08 01:21 PM
06/08/08 01:21 PM
Pittsburgh, PA
W
wayfarer1 Offline
wayfarer1  Offline
W
Pittsburgh, PA
What year 340 are you building? The LD 340 will not accept the later Thermoquad carbs. The Air-gap will perform and flow better and you can run any carb you want. I am using a Performer RPM on my stock 340 which is basically an Air-Gap without the flow thru design.
Joe
Current Project: 72 Roadrunner 340/727/Petty Blue/White Roof Strobe Stripe/Black Bucket Interior
71 Demon project
Re: Performer. Air Gap or LD340 Intake? [Re: wayfarer1] #69895
06/08/08 01:27 PM
06/08/08 01:27 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
For a stock build I'd go with the LD340. If you plan on more upgrades (cam, headers, head porting, etc.) I'd go with the Air Gap, it has the most potential of all 3 in a performance build.
Re: Performer. Air Gap or LD340 Intake? [Re: wayfarer1] #69896
06/08/08 01:27 PM
06/08/08 01:27 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
* The LD 'in stock form' will not accept a spreadbore carb. It was however cast with intentionally thick bosses on the carb mounting surface, so it can be safely hogged out to accept a Thermoquad or other spreadbore carb.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Performer. Air Gap or LD340 Intake? [Re: ScottSmith_Harms] #69897
06/08/08 01:43 PM
06/08/08 01:43 PM
NY
NY
Mine is a 73 340 motor. So it has the low compression 8:5. I though about seeing if I could boost the compression a little, but still keep it stock with a stock cam and use one of these intakes.
old340dog
Re: Performer. Air Gap or LD340 Intake? [Re: GO_Fish] #69898
06/08/08 01:44 PM
06/08/08 01:44 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
And the difference in performance between the Airgap and the LD340 will so close as to say that if you already have an LD340 that the purchase of a new AIrgap would not be even close to a cost efficient move.
Re: Performer. Air Gap or LD340 Intake? [Re: old340dog] #69899
06/08/08 01:46 PM
06/08/08 01:46 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
If you have the LD340 I would use that. If you need a new intake I would go with a Performer RPM. The RPM and Air gap are the same runner and height only difference being the "airgap" under the runners. I doubt you will see any gain from that and I feel its not worth th extra $100 over the regular RPM
I ran a LD340 on a low compression 340 and it always ran hard. I also used on a 11:1 340 that was ported for a Thermoquad. Great intakes.
Dont under estimate the stock spreadbore 340 intake though. If you all ready have one they perform great as well.
Re: Performer. Air Gap or LD340 Intake? [Re: ScottSmith_Harms] #69900
06/08/08 01:58 PM
06/08/08 01:58 PM
Upper Midwest
Upper Midwest
If going with a stock type rebuild and want a weight reduction go with the Performer littl eor very little gain there other wise. Performance build go with the LD340, RPM or Airgap. No comparison in any of these three to stock intakes and very close to each other.
Re: Performer. Air Gap or LD340 Intake? [Re: old340dog] #69901
06/11/08 07:52 PM
06/11/08 07:52 PM
Jasper, Indiana
fastnos Offline
fastnos  Offline
Jasper, Indiana
Gotta ask you a couple of questions first. Do you already have one or more of these intakes, or do you have to buy any one of them when you replace it? If building a 73 340, you might want to go with the earlier pistons and cam. 73's were lower compression and cam was a little different too. If your planning on going much over 5000rpm often, then you might look for a set of aftermarket heads. But just for a warmed over decent running 340, the factory ones will do fine. What do you plan on doing with it after the rebuild- daily driving with occasions of spirited driving, weekend warrior, or strictly a strip car with occasional street excursions? The cost of a rebuild for basically the same engine, earlier spec 340 vs. the 73 version should be close. The earlier parts should give you more bang for your buck tho. Just don't go too overboard.
On a basic stock rebuild, I'd use the LD340 if you can buy it reasonable, and modify it to fit the Thermoquad. If you really want performance then go with an air gap and Holley of your choice, with larger cam. The LD340 was a great intake to begin with, and for street driving, it is a great piece.
If you want to go a little faster, then you might want to get a junkyard 360 engine and go with a stroker version/kit for it. No need to go with a forged crank unless you want to go much over 450-500 HP. Cast cranks should last on a street car without too many problems. Just make sure your oiling system is up to par if you go that route.
Let us know what you decide.
A True Hybrid: Burns Gas AND Rubber!
Re: Performer. Air Gap or LD340 Intake? [Re: old340dog] #69902
06/11/08 07:56 PM
06/11/08 07:56 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
If you want to spend money or shave weight I would try to find an LD340. If you're not worried about weight I doubt you will feel any performance increase over the stock iron manifold in your application.
Sheldon
Re: Performer. Air Gap or LD340 Intake? [Re: MoparforLife] #69903
06/11/08 08:52 PM
06/11/08 08:52 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
can going to a RPM from a perform manifold result in a loss of performance on a mild engine?
Re: Performer. Air Gap or LD340 Intake? [Re: mark7171] #69904
06/11/08 08:58 PM
06/11/08 08:58 PM
Los Angeles, CA
Freiburger Offline
Freiburger  Offline
Los Angeles, CA
Not im my experience. The Air Gap will probably be better everywhere in the curve vs. a Performer.
Facebook.com/DavidFreiburger 70 Super Bee - 68 Charger - 68 Dart 75 Gremmie and 20-plus other junkers
Re: Performer. Air Gap or LD340 Intake? [Re: Freiburger] #69905
06/11/08 09:12 PM
06/11/08 09:12 PM
Upper Midwest
Upper Midwest
It would be a fluke if it happened. There is no comparison between the Performer and the Airgap.
Re: Performer. Air Gap or LD340 Intake? [Re: wayfarer1] #69906
06/11/08 11:11 PM
06/11/08 11:11 PM
clarks summit pa
73cuda340 Online content
73cuda340  Online Content
clarks summit pa
Joe
I thought that the Air-Gap could only accept a square bore carb.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
