a body fuel sender #698875
05/15/10 10:06 PM
05/15/10 10:06 PM
duster408 Offline OP
I am trying to get a new fuel gauge for a 71 duster. Does anyone know what ohms the repo or factory senders are? Thanks for the help.
Re: a body fuel sender [Re: duster408] #698876
05/15/10 11:13 PM
05/15/10 11:13 PM
IN
ahy Offline
ahy  Offline
IN
The standard spec is 73 ohms empty and 9.6 ohms full (from '70 Dart/Challenger FSM). The re-pop senders, however, tend to be inaccurate.
Autometer fuel guages set up for MOPAR factory specs (or real close) are available from Summit.
Re: a body fuel sender [Re: ahy] #698877
05/15/10 11:16 PM
05/15/10 11:16 PM
What Ahy said, alot of issues w different aftermarket ones not reading anywhere near correct. Make sure you select the right one
Re: a body fuel sender [Re: ahy] #698878
05/16/10 07:32 AM
05/16/10 07:32 AM
BDW Offline
BDW  Offline
from the FSM
