BB Motor Mount Brackets, Which Side? #698685
05/15/10 08:41 PM
05/15/10 08:41 PM
Roseville Ca.
Rob in Roseville Offline OP
Roseville Ca.
Hi Guys...
I just installed a 440 in my '73 b'cuda and am getting interference between the oem driver's side exhaust manifold and steering shaft coupler. I'm guessing I got the motor mount brackets on the wrong sides. It appeared they would only go on one way.
How do I know which bracket goes on which side? Does the one with the tube on it go on the passenger side? I currently have it on the drivers side.
Thanks,
Rob
'73 B'Cuda 440/727 Rolling Resto
Re: BB Motor Mount Brackets, Which Side? [Re: Rob in Roseville] #698686
05/16/10 10:32 AM
05/16/10 10:32 AM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
If you're using a set of these, then the tubed one goes on the driver's side:
