Should I be worried? (440 Source related)
#698503
05/15/10 02:19 PM
05/15/10 02:19 PM
Posts: 5,906 Athens, Greece
Pyper70
Athens, Greece
I never had a problem dealing with Brandon or buying his parts. I know some on the board have had issues with 440source's parts.
I went on the site to look for some shims for the rocker shafts I have. I had purchased a full set of roller rockers, aluminum hold downs and spacers from him for my RPM heads. I now cannot find any spacers or the rockers, nor the hold downs. Did he discontinue them or did he find that too many people were having problems with them, yanked them from the product line, and stopped selling them and avoids the people bought a set...like we have the plague.
I shot him an email last week about a distributor gear I purchased and he hasn't gotten back to me yet...Nothing is wrong with it. it was just an inquiry about the design and stock he has
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Should I be worried? (440 Source related)
[Re: Pyper70]
#698506
05/15/10 05:32 PM
05/15/10 05:32 PM
Posts: 118 South Jersey
JerseyJoe
South Jersey
I emailed a question recently and haven't heard back yet also. It's been a while since I've asked them a question, probably since Brandon was answering all the emails... 440source has grown alot in a short time, be glad your calls are not being routed to India....yet. Just sayin' if it's real important call 'em.
[Re: Stanton]
#698510
05/16/10 10:33 AM
05/16/10 10:33 AM
Pyper70
Athens, Greece
Got it...Found it all...At least they are still selling the products I have so they should be in working order without defects.
[Re: Pyper70]
#698511
05/16/10 04:13 PM
05/16/10 04:13 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
[Re: JohnRR]
#698513
05/16/10 06:28 PM
05/16/10 06:28 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
Funny. I haven't noticed this one before.
[Re: cdp]
#698515
05/16/10 11:22 PM
05/16/10 11:22 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
If was me, I wouldn't get the water pump housing unless they already corrected the water passages inside... make a search about.
[Re: NachoRT74]
#698517
05/17/10 08:34 AM
05/17/10 08:34 AM
Posts: 5,337 the house on the left.
cogen80
on page 7 the guy says its the water pump not the housing thats the problem.
http://www.dodgecharger.com/forum/index.php/topic,60599.0.html
. Quote:
Sorry guys... I ran these critters to the max and it looks as though the problem lies with differences in pump performance and not the housings.
I used a rig with unrestricted 1-1/2" inlets and outlets, and 1" recirc lines that let the pumps flow to the physical limits of the housings. The housings seem to peak out at about 40 gallons per minute (a flow rate your vehicle will never see due to restrictions in the radiator, thermostat, engine block, hoses, etc). Trying to push the flow rates harder than this resulted in a lot of.... well for lack of a better understood term... Bucking. This information is just trivia of course, but still interesting to note.
That said... I ran the 2 pumps that I had (the stock 8 blade Mopar & 440 source HV unit) on the 3 housings that I had ( the 2 stock Mopar styles {Left & Right}, and the "restricted" 440 source unit), and in each and every case the pumps flowed the same irregardless of the housing they were mounted on. In other words, the stock Mopar pump flowed better than the 440 pump, but it still flowed the same irregardless of the housing. Changing housings had no effect on flow rates.
Note that as the rpm's increased, the 440 source pump started to catch up with the stock Mopar unit, but in the end it was still just a little behind... but not enough to care about.
Ron used a $90 Milodon HV pump on his housing which Milodon claims can flow up to 30% better than the stock unit. Unfortunately, I did not have one of these lying around to test that theory along side the other 2 pumps, so we will have to take Ron at his word when he says that the Milodon can move some water. Ron's word has always been good enough for me so I won't argue the fact.
There would appear to be a considerable difference in performance between one pump and the next, especially at the all important lower end of the rpm scale. This low rpm performance is very important because as we all know, an hot engine idling in traffic is no place for a pump with poor flow characteristics.
So... take it or leave it... that's what I got using the limited equipment at my disposal.
cheers
[Re: cogen80]
#698518
05/17/10 08:54 AM
05/17/10 08:54 AM
Pyper70
Athens, Greece
Using the information from the passage above...what would happen if you used the 440Source housing and pump and put an underdrive pulley on the pump. It would zip the coolant right through wouldnt it?
[Re: Pyper70]
#698519
05/17/10 10:16 AM
05/17/10 10:16 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
The 440 source housing is fine.
[Re: JohnRR]
#698520
05/17/10 12:42 PM
05/17/10 12:42 PM
Challenger 1
Cincinnati, Ohio
This is exactly what I was gonna post a couple days ago. lol
