Thermoquad Whistling... #698197
05/14/10 11:34 PM
05/14/10 11:34 PM
The Dalles, OR.
Dusted_Ya Offline OP
The Dalles, OR.
Rebuilt a 9811S for someone and it is whistling when the throttle is depressed just a little then stops again if it's depressed more. What would cause this? Anyone have this happen to them before? It's quit obnoxious. Other than the whistling at say 1000-1200 RPM it runs great!
Re: Thermoquad Whistling... [Re: Dusted_Ya] #698198
05/14/10 11:44 PM
05/14/10 11:44 PM
The Sunny Shuswap
dodgefarmer Offline
dodgefarmer  Offline
The Sunny Shuswap
Wiggle the primary shaft by hand and see if the tone changes.
Randy
Re: Thermoquad Whistling... [Re: dodgefarmer] #698199
05/15/10 12:06 AM
05/15/10 12:06 AM
The Dalles, OR.
The Dalles, OR.
Well couldn't get the tone to change but does seem to be an awful lot of slop in it. Are these fixable?
Re: Thermoquad Whistling... [Re: Dusted_Ya] #698200
05/15/10 12:27 AM
05/15/10 12:27 AM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
How much slop? ... only fix is a new base or bushings in that one.
Re: Thermoquad Whistling... [Re: dOoC] #698201
05/15/10 12:30 AM
05/15/10 12:30 AM
The Dalles, OR.
The Dalles, OR.
pretty sloppy! Where do I get bushings?
Re: Thermoquad Whistling... [Re: Dusted_Ya] #698202
05/15/10 12:34 AM
05/15/10 12:34 AM
Florida STAYcation
Florida STAYcation
Put a dial-indicator on it. TALK to a machine shop in your area.
Re: Thermoquad Whistling... [Re: dOoC] #698203
05/15/10 12:54 AM
05/15/10 12:54 AM
The Dalles, OR.
The Dalles, OR.
Will Do.
Re: Thermoquad Whistling... [Re: Dusted_Ya] #698204
05/15/10 08:29 AM
05/15/10 08:29 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
Whistling is not likely the throttle shafts, check to see if there are two air holes inside the choke housing toward the front. That is where the whistling is comming from.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Thermoquad Whistling... [Re: Rapid340] #698205
05/15/10 08:41 AM
05/15/10 08:41 AM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
Or the whistling could be coming from the air bleeds. I drilled my air bleeds out on my thermoquad and after that my carb started whistling too!! Check to make sure they are good and clean. You'll have to take off 2 small covers on the top of the carb to expose them.
Re: Thermoquad Whistling... [Re: dmerc] #698206
05/15/10 11:15 AM
05/15/10 11:15 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
mine whistles at a certain idle rpm, shafts are tight, i have the choke removed, but if i put the air cleaner on, cant hear it. Might be just one of those things The real trick is tuneing it without A/F meter.
Re: Thermoquad Whistling... [Re: Rapid340] #698207
05/15/10 12:39 PM
05/15/10 12:39 PM
The Dalles, OR.
The Dalles, OR.
Thanks for the help everyone! I narrowed the whistling down to inside the primary housing. Not the air bleeds inside the housing either as I plugged them with my fingers and if I cover the primary housing inlet with a towel it gets quieter so looks like I'm gonna have to rebush the shafts... unless there's something else I should check inside the primary housing???
Re: Thermoquad Whistling... [Re: Dusted_Ya] #698208
05/15/10 12:55 PM
05/15/10 12:55 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
The two holes I am refering to are not small air bleeds. I am guessing .100 inch.
Look closely, staight back from the front two top fasteners. There is not a problem but they will wistle.
Re: Thermoquad Whistling... [Re: Rapid340] #698209
05/15/10 02:27 PM
05/15/10 02:27 PM
Martinsville, VA
440child Offline
440child  Offline
Martinsville, VA
Are you running a thin carb-to-intake gasket? I've seen cases where guys didn't have the carb tightened down quite enough & it sucked air past the gasket. Kind of like the comb & tissue paper thing
Re: Thermoquad Whistling... [Re: 440child] #698210
05/16/10 03:16 AM
05/16/10 03:16 AM
The Dalles, OR.
The Dalles, OR.
If your referring to the two holes inside front of the air horn... Yes I checked them by plugging them with two fingers. I am running a thin 4 hole gasket but I always make sure I tighten carb down in steps to about 3000 ft. lbs... okay maybe 25. I picked up some bronze bushings at the local true value in town. I'll cut them to size and stick them in the deep freeze till I have time to install them. Like I've said I've taken the truck to town a couple of times already on test drives and it performs flawlessly other than the whistle.
Re: Thermoquad Whistling... [Re: ademon] #698211
05/16/10 05:48 AM
05/16/10 05:48 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I ran a TQ for years on the GTX, they will whistle at certain throttle openings.
Most of the time you don't hear it unless you have an open air cleaner.
Re: Thermoquad Whistling... [Re: gdonovan] #698212
05/16/10 07:15 PM
05/16/10 07:15 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
I had a Thermoquad from the south at one time. It whistled Dixie when I drove the car.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: Thermoquad Whistling... [Re: MY340] #698213
05/16/10 10:21 PM
05/16/10 10:21 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I have piles of TQ's. Everyone has a sloppy throttle shaft on the primary. Bush it as it will cause a lean condition+sticking throttle!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
