2000 pt cruiser problems ? #697992
05/14/10 08:13 PM
05/14/10 08:13 PM
Just South of The Motor City
limechallenger Offline OP
My daughters 2000 PT just started surging(idle) about 500 rpm up and down! 2.0l 4 banger automatic,just thought I'd check with you guys first to see if you know of any common problems! Thanks in advance!
70 T/A Challenger 78 Aspen R/T 87 Indy 500 Dakota
Re: 2000 pt cruiser problems ? [Re: limechallenger] #697993
05/14/10 08:32 PM
05/14/10 08:32 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
clean the throttle body and clear the adaptive memory.
They are all 2.4L here....
Re: 2000 pt cruiser problems ? [Re: RodStRace] #697994
05/14/10 08:40 PM
05/14/10 08:40 PM
what do I clean the throttle body with and clearing the memory is to disconnect the battery correct?
Re: 2000 pt cruiser problems ? [Re: limechallenger] #697995
05/14/10 10:28 PM
05/14/10 10:28 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Is the a/c compressor cycling.
Re: 2000 pt cruiser problems ? [Re: RodStRace] #697996
05/14/10 10:38 PM
05/14/10 10:38 PM
Kansas, USA
V
Venomvpr900 Offline
Venomvpr900  Offline
V
Kansas, USA
brake clean, carb clean, mopar combustion chamber cleaner works the best! Pop the Thottle body off, remove the tps and IAC sensors and clean it out
1987 D-100 SWB, 390hp/360ci Mopar Performance Crate, Built 998 trans, 9.25 axle with sure-grip and 3.92's - 3960#'s with driver 13.83 @ 96.36 1.98 60 ft 2003 Dodge Ram 2500 HD 5.7ltr HEMI!!!
