Dyno pull feedback
#697611
05/14/10 08:19 AM
05/14/10 08:19 AM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
Hi all I just wanted to get your feedback on my build and give me some pointers on where I should go from here. This was my first trip to the dyno, so I didn't know what to expect. First off here is the mill 440 bored .40 over total cubic inches are 448 set of stock aluminum 440 source heads 1.5 stock rockers comp xtreme cam XE268H 480 lift .050 224degree/230 degree Holley Street Dominator intake headman shorty headers 1 3/4" at 2/5 inch collectors 800 cfm Thunderseries edlebrock carburator Jetted up 2 sizes 3860 lbs with me in it. hp 304 and torgue at 416. A couple of nice things about the graph. I have a very nice broad power band it arches well between 4600 and 5400 rpms. As is a rule my 440 is a torque monster. It seems to make my Converter flash about 3300. The torque band is pretty impressive and remained high through the whole run. Now we are going to continue to work on this a bit. The guy who runs the dyno has a father who is a carter expert and he is going to look at it as well as take some time to adjust timing with it and we will do it again. For the most part, I was hoping for more, but am satisfied for what the engine is, which is a mildly built big block car. Mike
1969 Dodge Dart Swinger
Re: Dyno pull feedback
[Re: MikeyT]
#697613
05/14/10 11:50 AM
05/14/10 11:50 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
oops it's an automatic . You have what appears to me to be about 100hp of drivetrain loss . What work was done to the heads , if any ?
[Re: JohnRR]
#697614
05/14/10 07:25 PM
05/14/10 07:25 PM
MikeyT
Watertown, WI
no work done to the heads, out of box put them on the car. 100 hp loss of the auto (gasp) really?
Mike
[Re: 1badx]
#697616
05/15/10 01:50 AM
05/15/10 01:50 AM
MikeyT
Watertown, WI
Thanks Mike for the perspective. My buddy Nate ran the set up and he has bee doing it for year so I think it was a good set up, my only question is weight, what if the car weighs a little bit more then the 3860 lbs listed?
Mike
[Re: MikeyT]
#697619
05/15/10 08:15 AM
05/15/10 08:15 AM
JohnRR
U.S.S.A.
Mike
The dyno doesn't care how much the car weighs , weight only comes into play for dragstrip calculations.
Considering the heads were run out of the box I guess that's not a bad HP number .
[Re: BSB67]
#697620
05/15/10 10:36 AM
05/15/10 10:36 AM
MikeyT
Watertown, WI
For what you have, I think those are good numbers. Did you have an et and mph goal?
My hope is to get solidly into the 12's. This might not happen, but last fall I had one run of 13.68 at around 105 mph, yet that was with 3:91 gears in it. This pull was done with the 3:23's in it.
However looiking at it, it seems like 3:91's are the best gear for me, because I would cross the traps at between 5400 and 5700 rpms.
The car fills like it might even like more jetting, it took the largest ones I had in the Eddy kit.
Yet, fuel seemed good most of my pulls put 02 at 12.5 and at top point 14.1 AFR with it averaging out to be 13.1 AFR across the whole run, so perhaps a little more tweaking is in order!@
Mike
PS for the record this engine performaed with the timing set at which is 16 initial and 36 total all in at 2800 rpms.
[Re: MikeyT]
#697623
05/15/10 11:37 AM
05/15/10 11:37 AM
Posts: 2,840 Flint, Michigan
B1Fish540
Flint, Michigan
Is that the real un-corrected power numbers or the SAE corrected power numbers? Anyhow, it looks good considering how small the cam is for that combination.
LOL, I alwaysd thought it was a nice middle sized cam, I guess not!! I'm not up on my dyno lingo,but I beleive uncorrected power numbers. I know it was 70 degrees out and not overly humid for the day, but I can't give you humidity stuff.
Mike
Mike
Mike another option would be to swap in some 1.6 ratio rockers ...that would give you over .500 lift w/your present cam. Better yet would be the .509 cam with 1.6 rockers for around .535 lift. Then , you would be letting those heads work and gain about 50 hp. 440s like to breath, thats why the Holley 850 db would be the "best" choice.
[Re: JohnRR]
#697624
05/15/10 02:26 PM
05/15/10 02:26 PM
Posts: 807 Toronto, Canada
dirtybee
Toronto, Canada
Mike
the one time i went on a chassis dyno the operator had to enter the vehicle weight maybe some are different
[Re: MikeyT]
#697625
05/15/10 06:08 PM
05/15/10 06:08 PM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
Mike
I guessed a little more mph with your RWHP and weight, but not much, like 107. Keep tuning, and practicing your launch and you could see high 12s in good air without changing anything else.
[Re: dirtybee]
#697627
05/15/10 07:04 PM
05/15/10 07:04 PM
Posts: 411 Portersville, Pa
1badx
Portersville, Pa
Mike
Actually the weight does matter. On our Mustang dyno the more weight you add the more the dyno loads (or applies braking force) the car during a pull. Now if the question is how much will it affect your horsepower I'm not sure, it may not affect it at all or it may put the car in a load range it may never see. It doesn't look like the weight difference was substantial so I wouldn't loose sleep over it. We have doubled a cars weight to experiment with quicker boost rise and the total horsepower with correction factor did not vary that much.
[Re: 1badx]
#697628
05/16/10 11:31 AM
05/16/10 11:31 AM
MikeyT
Watertown, WI
Thanks everybody for input. I certainly appreciate it. Now, I want to look at tweaking things a bit. Mike PS no Rob, I'm not putting a 950 DB on my 440! I like my taxicab carburator!
[Re: dirtybee]
#697629
05/16/10 04:16 PM
05/16/10 04:16 PM
JohnRR
U.S.S.A.
Mike
can't remember being asked that and I've been on superflow and a mustang ...
[Re: 1badx]
#697630
05/16/10 04:19 PM
05/16/10 04:19 PM
JohnRR
U.S.S.A.
Mike
I did a dyno shootout in CT on a superflow, i think , and there was a guy with a dually that took off his outer rims to see if he could get a higher number because he was upset thata the big name shop that his truck was the test mule for was bested by some low life ... me ...
Maybe the dyno operator didn't know what he was doing ?
