I picked up an 800dp 4780-2 in decent shape, choke towers been milled, still retains the original metering blocks, right now i'm running a 650dp with the choke tower milled, plus i blended the bottoms of the MB so it matches up with the 1.11/16" base, i'm sure its flowing around 700 cfm, how many of you feel the 800dp will be too much for this combo, i've already ran the car last week, ran 12.5s with timing at 30*, here is the combo.
71 swinger, no PS/PBs or AC, race weight un-known.
95 360 magnum, stock short block with some miles on it.
RHS magnum heads (baseline) from hughes.
re-ground factory cam from bullet, .477/.477, .218/.218 @50 with factory 1.6 rockers, Crosswind RPM, 650dp (70/76 jets), summit headers, summit turbos, 2.1/4" exhaust.
904 with cheetah VB, PTC 11" 2800, spooled 3.73s, 255/60/15 MTs, its pulling 17 inches vacuum with timing at 30*, my shift points are 5200. So should i drop on the 800dp
, i drive this car 50 miles to the track, so i don't want to be changing carbs out there, just curious what some think.
