aluminum rods in a smallblock...questions.
#697490
05/13/10 11:14 PM
05/13/10 11:14 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
when would i want aluminum rods in a smallblock what are the perameters that dictate..they are needed..? what about aluminum rods...are bad..? why wouldnt i want them in my build? race car...prolly a stroker..with no2.. maybe boost if i hit the lottery..lol..
if i have aluminum rods in my motor..what do i do differently ...as far as a normal race scenario. anything special that has to be accounted for? temp? breaking,cycle life.. cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
Re: aluminum rods in a smallblock...questions.
[Re: POS Dakota]
#697492
05/14/10 11:17 PM
05/14/10 11:17 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Anytime you are pushing the limits of the block you are using and stand a risk of detonation.
When you run a steel rod any vibration especially detonation beats the bearing and then beats the crank many block get hurt from this.
You never want to beat on the engine cold. Refrain from using the engine to slow car down. And extreme oil temperature is hard on them.
If you plan to sit in traffic for long periods of time. If you plan to run your engine stupid hot or go out on a 30 degree day start the engine and rev it to 8,000.
When you run one of these power adders you will likely detonate. Most people don't realize this but when you detonate you can actually lift the heads off the block just from the vibration. You pull the bottom end down and see main cap walk. Alluminum rods absorb this and save the other parts. You just need to replace them they don't last forever like steel rods. Steel rods kill the block so it's a tossup. I run them in everything.
Heat and cold cycles is what wears out the strenght in alluminum rods. Some say they look at a visit to the dragstrip one long heat cycle. I guess that just depends on the racer.
