Semi floating pins?
#697402
05/13/10 09:47 PM
05/13/10 09:47 PM
Posts: 1,200 UK
602heavy
UK
Putting together a 512 stroker (RB) , the pins are a press fit into the rods & float in the piston pin bore , clearance between wrist pin & spiro locks are around .015" (float) , seems pretty tight to me? ,any thoughts?
Post deleted by Defbob
[Re: 602heavy]
#697403
05/13/10 09:50 PM
05/13/10 09:50 PM
Re: Semi floating pins?
#697405
05/13/10 09:58 PM
05/13/10 09:58 PM
Posts: 1,200 UK
602heavy
UK
These are fully floating , pin seems a tad tight in the rod.
[Re: Bob_Coomer]
#697409
05/13/10 10:17 PM
05/13/10 10:17 PM
Posts: 1,200 UK
602heavy
UK
Should of worded this a little better from the start . sorry..................
The kit uses fully floating pins , the pin is a tad tight on the rod , should i leave as is or get them honed?
[Re: 1974PW]
#697411
05/13/10 10:34 PM
05/13/10 10:34 PM
Posts: 1,200 UK
602heavy
UK
your running a floating pin on a none bushed rod?? is the pin coated at least?
Made a complete mess of my first post , rods ARE bushed , my brain seems a bit messed up tonight.
[Re: 602heavy]
#697412
05/13/10 11:02 PM
05/13/10 11:02 PM
if the pins are tight in the rods, have them honed to the proper fit for your application.
[Re: 602heavy]
#697415
05/14/10 08:29 AM
05/14/10 08:29 AM
Posts: 75,080 U.S.S.A.
JohnRR
U.S.S.A.
The wrist pins were supplied with the pistons & rods . you would think they would be clearanced for correct fit (.0006"/.0003"?) , just seems anothe set back when putting these things together.
Takes a light tap with a mallet to slide these pins into the rod bushings , tad more than a thumb fit.
Just because it came as a set doesn't mean a thing , unless you paid to have it pin fit by the supplier then they do as little as possible .
