tranny jack #697109
05/13/10 02:42 PM
05/13/10 02:42 PM
Ball Ground GA
TrueTripleX Offline OP
Ball Ground GA
Who can recommend a good brand of inexpensive telescoping transmission jacks.
Re: tranny jack [Re: TrueTripleX] #697110
05/14/10 08:32 AM
05/14/10 08:32 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Seeing as I need one, also....
Re: tranny jack [Re: TrueTripleX] #697111
05/14/10 10:14 AM
05/14/10 10:14 AM
Ohio
B5TA Offline
B5TA  Offline
Ohio
TripleX, I bought one about 3 years ago from Harbor freight. It was middle to the best that they sell, has air motor also saves some pumping. One of the first jobs was a '91 Chevy K1500 manual and transfer case , handled it with no problems. It has a main cylinder O.D. of around 4" dia. Always get a little heavier than what you think you need Kev
Re: tranny jack [Re: B5TA] #697112
05/14/10 05:17 PM
05/14/10 05:17 PM
Commando1 Offline
Commando1  Offline
Amazing how more and more threads are coming back with the reply as "Harbor Freight"
Scary....
Re: tranny jack [Re: Commando1] #697113
05/14/10 05:25 PM
05/14/10 05:25 PM
Ball Ground GA
Ball Ground GA
Scary....
Commando1 and B5TA, to let you know, I tried Harbor Freight and the guy there told me that they discontinued the tranny jack. Please keep the ideas coming
Re: tranny jack [Re: Commando1] #697114
05/14/10 05:29 PM
05/14/10 05:29 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Scary ? ...... whatchootalkinabout ?
The prob with ANY type of SPECIFIC trans-jack .. is you have to get the car HIGH up in the air.
I have never used one ... but I have heard of good reports of the bracket you put in/on a FLOOR JACK.
Just put the car up on jack-stands .... slide the trans uNder the car .... the same with the floor-jack and bracket THEN heft the trans up ON the bracket.
Re: tranny jack [Re: dOoC] #697115
05/14/10 07:22 PM
05/14/10 07:22 PM
IN
ahy Offline
ahy  Offline
IN
I got one from JC Whitney that works fine.
Re: tranny jack [Re: dOoC] #697116
05/14/10 09:13 PM
05/14/10 09:13 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Yep that's the way I do it too, but I think they are looking for a shop type jack that will be used under a lift with the car over head.
Re: tranny jack [Re: TrueTripleX] #697117
05/14/10 10:22 PM
05/14/10 10:22 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I just got the two stage ranger trans jack, RTJ-1, but have not used it yet. it was $570 (includes shipping) and has the 4-way tilt saddle. goes 37" to 79.5" and shipping weight is 214 lbs. It looks like in may have been "harbor freight" as the manual references that accessories can be bought at harbor freight?
I was just looking at the Northern Tool catalog, and it looks like they sell a very simular trans jack under their house name "Torin TR4055" 1/2 ton trans jack, and it is $300 without shipping. It looks like it only tilts up/down, but not side to side. Lift range listed as 34-5/16" to 70-15/16" and weighs 175 lbs, so I guess the ram is slightly smaller? I'm not sure which is the better deal, the Northern tool one would cost an additional $120-$200 for shipping, but that is still about $100 less expensive. I got the Ranger from ASEdeals.com because I wanted the extra lift height, and I didn't want to get a cheaper one and be disapointed with it and end up buying one like this in the future anyhow. Don't forget to get hydraulic oil at the same time.
Re: tranny jack [Re: TrueTripleX] #697118
05/14/10 10:35 PM
05/14/10 10:35 PM
Ohio
B5TA Offline
B5TA  Offline
Ohio
Re: tranny jack [Re: B5TA] #697119
05/14/10 11:40 PM
05/14/10 11:40 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
i did mine on the floor with a motorcycle jack from sears...on sale was about 70.00 dollars..
Re: tranny jack [Re: AARCONV] #697120
05/15/10 10:02 PM
05/15/10 10:02 PM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
Me too -- except mine came from Checker/O'Reiley and I got it 50% off -- whopping $49.95! Car was up on ramps and then jacked up just a little higher to unload the suspension. Worked great. :-)
Re: tranny jack [Re: Hotwheelsjr] #697121
05/15/10 11:09 PM
05/15/10 11:09 PM
Wichita, KS
tmef Offline
tmef  Offline
Wichita, KS
I have one of these. I like it.
http://www.pacetools.com/Products/TJ-2158
Re: tranny jack [Re: tmef] #697122
05/16/10 10:37 AM
05/16/10 10:37 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Re: tranny jack [Re: gtx6970] #697123
05/16/10 04:42 PM
05/16/10 04:42 PM
Commando1 Offline
Commando1  Offline
anyone have one of these ?
http://www.completehydraulic.com/hydraulic-jacks-jm8050d.html
Killer deal if freight doesn't kill it.
Why is it a killer deal?
Look: not so killer deal
