Re: tips for leak free SB oil pan?
[Re: 440newport]
#696815
05/13/10 10:04 PM
05/13/10 10:04 PM
Posts: 15,489 the boonies
aarcuda
the boonies
Yeah I saw your other post. I believe mine was the same way the last time I changed it. The rear rubber seal stuck up past the edges of the pan, it didn't really fit the cap properly either, so I cut about 1/2" out of it and superglued it back together. The front seal wasn't much better, it didn't sit flat with the pan rail, they were kinda angled upwards at each end. I didn't take the pan off the engine to have a look yet, but I'm thinking the milodon pan must have some differences compared to the stocker.
mine was like that too!! on my 340 though. i told milodon about it last year and they want me to send the oil pan to them so they can look at it. but then my car would be missing an oil pan while they look at it.
but same thing, the ends of the rear seal on the pan is way too far up and i need to trim down fluch to the sides. the little titts didnt fit the holes either
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
[Re: pishta]
#696818
05/14/10 12:54 AM
05/14/10 12:54 AM
Posts: 27,467 So Cal
autoxcuda
So Cal
How about the 1 piece pan gasket?
They are really made for magnum motors. And there is difference in the front corners that needs to be filled with a small piece of metal or a bunch of silicone. There are no tabs to fit the older pans too.
Mine leaks like a sieve since the day I installed it on my 360.
[Re: autoxcuda]
#696819
05/14/10 08:26 AM
05/14/10 08:26 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Make sure the rails are flat around the bolt holes and contact Roadhazard about one of his Superformance gaskets.
[Re: dvw]
#696822
05/14/10 09:53 PM
05/14/10 09:53 PM
Posts: 4,588 St. John's Newfoundland
440newport
I agree the pan stampings are poor at best. I used a 36 grit 3" 3M dicc to reshape the rubber end seals to the shape of the new pan. I cut the cork gaskets slightly short so there is a slight gap between them and the rubber end seals. Glue the cork gaskets to the block with 3M weather strip adhesive. A thin bead of sealer on the rubber end seals and between the cork and the pan(this fills the inconsistances in the pan). Be carefull and do not over tighten. Don't allow the cork or rubber end seals to "push out" when tightening. This methods will seal the pan. I use the G.M. factory light grey colored sealer,it sticks better than any I've tried. My pan doesn't seep a drop. good luck Doug
Do you suggest putting a bead of sealer all around the cork and not just at the ends? And the same for the rubber seals? On the whole thing and not just where it meets the cork?
[Re: chache876]
#696823
05/14/10 10:03 PM
05/14/10 10:03 PM
autoxcuda
So Cal
I called up Milodon today and they said my pan might not have been cut deep enough for the seal and to send it back to summit for an exchange. I asked if it was a common issue and he said no.
I'm going to exchange it but it still doesn't explain why the seal doesn't fit correctly on my block. Mines a magnum 5.9 but it should fit the same as a LA block.
I think you need to investigate that further. Search Moparts. I know it's been discussed before. AndyF was the last person I saw that brought it up.
Next time I see Milodon, I bring it up.
[Re: 440newport]
#696825
05/15/10 04:02 PM
05/15/10 04:02 PM
Posts: 9,835 MI, usa
dvw
MI, usa
Yes,I use it everywhere except between the cork and the block. Doug
[Re: 440newport]
#696830
05/16/10 12:12 AM
05/16/10 12:12 AM
Posts: 892 USA
krw71ragtop
USA
My 360 has had an annoying leak from the oil pan ever since I changed over to 8qt mildodon pan last year. I've since tried to replace the gasket with the engine still in the car again to no success, I rtv'd around the whole thing that time which was probably a mistake. Last week I pulled the motor to repaint it and fix the few leaks I have.
What should I put on the pan gasket? Should the cork be dry or should I use some sort of sealant or adhesive? When I built the motor 6 years ago and put on a stock pan, I remember I only used a little rtv in the corners where the cork meets the rubber ends and it seemed to be leak free then....
I have the same issues with my 416" (340) with Milodon pan. Rebuilt motor with 288 miles on it and oil pan starts leaking. Pulled headers and pan, replaced gasket and rear main seal. Then pulled motor for dyno. Made about 8 dyno pulls and no leaks. Installed motor in car and it wasnt fired up for 1 year. After motor was fired up about 3-4 times and wasnt run over 3000 rpm's, the pan started leaking again !
My front and rear seals were on the tall side too. I'm building a 410" (360) right now and using a Milodon pan. Just checked the front and rear seals and they are too tall also. I'm really getting tired of having to modify these after market parts. Headers, starter, distributor, bell housing, rocker arms, and convertible top hoses, just to name a few (high dollar) parts that I had to modify to make fit.
