Big Inch Six Pack Motor #696757
05/12/10 10:59 PM
05/12/10 10:59 PM
Southern Illinois
Rocket65 Offline OP
Rocket65  Offline OP
Southern Illinois
Okay, folks... I am rebuilding a 440 six pack motor and am looking into 440 Source stroker kits. I want to keep the six pack set up but know that the manifold is my bottle neck in the whole combination. Anybody out there running this combination? If so, what advise can you give? I am thinking of staying in the 500-512 C.I. range. Head selection is going to depend on what I can get out of the intake, thereby dictating cam selection... dictating cubic inch limitations. What say you, oh knowlegable ones?
'65 Satellite - 512 6BBL; 10.8:1; 3600 Stall RMVB; 4.10:1 Dana w/Locker... Still tuning, going to the track soon!
Re: Big Inch Six Pack Motor [Re: Rocket65] #696758
05/12/10 11:09 PM
05/12/10 11:09 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Re: Big Inch Six Pack Motor [Re: Rocket65] #696759
05/12/10 11:22 PM
05/12/10 11:22 PM
AndyF Offline
AndyF  Offline
All depends on what you're trying to accomplish and how big your budget it. Dwayne Porter is a good person to talk to. He can handle the head porting and the cam selection to get the most out of a big inch 440+6.
Re: Big Inch Six Pack Motor [Re: Rocket65] #696760
05/13/10 12:19 AM
05/13/10 12:19 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
I'm running a 496" 440Source stroker in my Challenger.
Still have the stock un-touched aluminum intake on there, and using Eddy Performer RPM untouched 84 cc heads. Using a XTQ294S Comp solid with 928 Comp springs.
The carbs have had "LOTS" of tinkering to get everything to work well together.
The car will run 10.90's easily and I know there's more in it with some ssuspension work as it has a bad habit of spinning about 20' out of the box on a so-so track.This is 3650# with the driver. so it isn't a light car. I think the 620#'s of torque probably has some bearing on this!
A good roller cam would probably net another tenth or so, and the intake can be ported out by Hughes Engines to their Stage 2 specs. Those intakes actually will flow pretty good for a dual plane if they're worked over.
Re: Big Inch Six Pack Motor [Re: Rocket65] #696761
05/13/10 12:42 AM
05/13/10 12:42 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Mopar Muscle Magazine is supposed to be doing an article on John Godshacks' (not sure i spelled the name right) 1969 A12 SixPack Superbee that was at Mopars at the Strip, and I think he was also in the true street challange? He is running a 440 Source stroker kit with out of the box stealth heads, a hydraulic flat tappet cam (Hughes I believe?), and the stock 6-pack setup. The stock 833 4-speed was rebuilt with with the 4th gear overdrive (3rd is now 1:1.)
Re: Big Inch Six Pack Motor [Re: 451Mopar] #696762
05/13/10 08:38 AM
05/13/10 08:38 AM
Ohio
70BIRD Offline
70BIRD  Offline
Ohio
I'm currently having a 496 stroker being put together by Nick Wilson at Compuflow and it should be on the dyno within the next 2 weeks so I will have some better info then but as far as flow numbers I have aluminum Indy SR's that Nick ported and he told me they are flowing 329 CFM on the intakes and with the 6 pack manifold attached the flow varied from 276 CFM (#1) to 285 CFM (#5 I think). Even though the 6 pack manifold has a stage II porting done by Hughes I was surprised at the big drop in flow.
Paul
Re: Big Inch Six Pack Motor [Re: 70BIRD] #696763
05/13/10 09:43 PM
05/13/10 09:43 PM
NY
W
WICKD6PK Offline
WICKD6PK  Offline
W
NY
yepper im runnin their 512 kit with my six pk set up and had nitrous express plumb up a direct port fogger system. 727 trans-- dana 60-- eddy heads-- i did use all of the upgrades from promax they make tuning those carbs a breeze--a little time consuming--but easy. once you get it dialed in your good to go
Re: Big Inch Six Pack Motor [Re: superwrench] #696764
05/14/10 08:08 AM
05/14/10 08:08 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
"stock untouched ALUMINUM heads" What year was that option ???
Re: Big Inch Six Pack Motor [Re: terzmo] #696765
05/14/10 10:27 AM
05/14/10 10:27 AM
superwrench Offline
superwrench  Offline
I don't see any reference in my reply about "stock" aluminum HEADS !
Re: Big Inch Six Pack Motor [Re: Rocket65] #696766
05/14/10 12:26 PM
05/14/10 12:26 PM
I guess it has to do with what your total combo is and if you are going to run aluminum heads and headers or not.
My intake is untouched from the factory. I have a 523 stroker (440 source kit and .060 over) in my six pack Super Bee. I had this car built to basically be legal for F.A.S.T. racing if it ever comes to be in the southwest. My engine is a 73 and did not have the 906 heads but rather the 452s(?) so we used them as they are pretty much the same heads anyway. it has a roller cam, balanced and blueprinted, all the Pro Max mods, around 10.5 CR etc. The top guys in the F.A.S.T. racing are running around 14. t0 1 CR but i wanted to be able to run my car on the street as well. The engine builder told me that the intake is really not such a big bottle neck in my case as i am running factory exhaust manifolds and full exhaust. I have not finished my car as it still needs paint so i have not had it to the strip, but it "feels" it is a 11.5 second car on drag radials or maybe a little faster.
Re: Big Inch Six Pack Motor #696767
05/14/10 12:42 PM
05/14/10 12:42 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Aluminum intake, heads and headers saves a lot of weight over the cast iron versions of those three components too.
Does anyone happen to know what the weight savings might be? It must bring the overall 440 weight down to the small block weight range, no?
Re: Big Inch Six Pack Motor [Re: jbc426] #696768
05/14/10 01:02 PM
05/14/10 01:02 PM
Bel Air Maryland USA 21014
wmwalden Offline
wmwalden  Offline
Dwayne Porter was my go to guy. He ported my set of factory heads and picked the cam for me. A solid lift comp. I took my 440 to the 512 mark. Wish I would have gone to 528. But all in all the car performs well. Has great street manners as well as plenty of go power. Last weekend took to the track. Best time was 11:41 @ 117.6
I have a 71 Challenger that weighs in at 3967 with me in it.
You will find that you need a good converter to wake the motor up. Currently I run a 3800 with 3:54 gears.
I get about 14 mpg when not into it. LOL
If running it you can watch the gas gauge fall.
Definitely use the ProMax mods to tune the carbs. What a pain it is the remove the carbs for tunning. Like it was stated, once tuned they are pretty much set and goooooo.
Re: Big Inch Six Pack Motor [Re: jbc426] #696769
05/14/10 01:18 PM
05/14/10 01:18 PM
AndyF Offline
AndyF  Offline
Heads save about 50 lbs, intake another 15 to 20. If you go with the aluminum water pump housing that saves a chunk of weight as does a mini-starter. Engine will still look stock after a coat of paint, especially if you use the Stealth heads. You can save more weight with the new aluminum float bowls for the Holley carbs. Aluminum distributor saves some weight. Stroker motors are usually lighter also, espeicially if you buy a high quality crank and go with the BB Chevy rods.
Re: Big Inch Six Pack Motor [Re: AndyF] #696770
05/14/10 03:36 PM
05/14/10 03:36 PM
In addition to the weight savings the aluminum heads allow for higher compression without the same detonation with the same spec'd inron headed engine.
Re: Big Inch Six Pack Motor [Re: Rocket65] #696771
05/15/10 12:19 AM
05/15/10 12:19 AM
iowa
copchaser Offline
copchaser  Offline
iowa
The 6-pak manifold is a lot better than most think. I've got a very nice pump gas 712 horse 535. A couple of years ago I did a manifold test on the dyno and I posted the results on here. I found the 6-pak is a great manifold as long as it's kept under 6500RPM. You can keep your crossram and tunnel ran manifolds.
Re: Big Inch Six Pack Motor [Re: Rocket65] #696772
05/15/10 05:33 AM
05/15/10 05:33 AM
Sweden
K
kennetto Offline
kennetto  Offline
K
Sweden
yesterday we did a dynodrive on my new stroker here is the numbers.
block chenoweth block in a bag 440 0,30 over, deck height 0,013 bore 4,3500 stroke 4,150
440 source stroker kit rod lenght 6,7600 flat top pistons
heads edelbrock 84 cc,s gasket felpro 1009
compcam roller rockers
camshaft straighlines performance
lobe lift intake 0,360 exhaust 0,345
rocker ratio 1,5 1,5
valve lift 0,540 0,518
adv dur 294 309
dur@.050 244 256
lobe centerline 108,0 116,0
lobe separation 112
carbs holley six pack
ignition pertronix distrubutor and second strike box
exhaust tti 2" headers
result 540 hp 5500 rpm
torque 587 4400rpm
Re: Big Inch Six Pack Motor [Re: Rocket65] #696773
05/15/10 07:13 AM
05/15/10 07:13 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Hughes ports and flows those intakes and gets a lot more out of them.
Re: Big Inch Six Pack Motor [Re: copchaser] #696774
05/15/10 09:39 AM
05/15/10 09:39 AM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
I would like to hear more about your 712HP pump gas combo.
What compression ratio,heads,carbs,cam,header size,iron block or aluminum,etc,etc...
Re: Big Inch Six Pack Motor [Re: Rocket65] #696775
05/15/10 01:02 PM
05/15/10 01:02 PM
Southern Illinois
Rocket65 Offline OP
Rocket65  Offline OP
Southern Illinois
Great information from everyone! I really appreciate you input, and there is a lot of meat to chew on here. I may very well tap into some of the resources y'all have recommended.
So here's what I am thinking:
512 - 528 C.I.
Ported Eddy Heads
Massaged Six Pack Manifold
Roller Cam - specs depend on manifold/head flow numbers
Comp Roller Rockers... probably 1.5:1
Viscous Damper
True Roller Timing Chain
Six Pack with Pro Max Mods (already have)
Melling H.V. Oil Pump (already have)
TTI 2" Headers (already have)
3" Exhaust w/X-Pipe (already have)
Electronic Ignition w/chrome ECU (already have)
Mini Starter (already have)
Aluminum H2O Pump (already have)
Charlie's 8Qt. Pan (already have - will need the stroker windage tray)
Aluminum Radiator (already have)
Modified T-Flite (A&A and Cope parts)W/Dynamic 3600 Stall (already have)
Mark Williams Dana 60 w/35 Spline Axles, Locker and 4.10:1 Gears (already have)
MW 3" Chrome Moly Driveshaft w/1350 U-Joints (already have)
295-60-15 Mickey Thompson Drag Radials (already have)
Super Stock Springs relocated into frame (already have)
I think I am set up to build a stout combination here and have taken advantage of a lot of weight saving opportunities. I try to use the best stuff I can get my hands on... you know... "You get what you pay for..."
But the $100,000 question is: does anyone know the magic word to get the guys at Modern Cylinder Head to answer the phone? I tried saying "Cha-CHING" over and over on their voicemail. Normally that works...???
Re: Big Inch Six Pack Motor [Re: Rocket65] #696776
05/15/10 03:25 PM
05/15/10 03:25 PM
AndyF Offline
AndyF  Offline
Buy the heads from Mancini Racing, they'll get them ported at Modern for you. Or if you already have the heads and can't get Modern to answer the phone then send the heads to Hughes.
