Paint stripping an engine bay, how do you do it? #696571
05/12/10 09:30 PM
05/12/10 09:30 PM
Manitoba, Canada
DaytonaTurbo Offline OP
Manitoba, Canada
I've been in the process of stripping my engine bay down to bare metal and wow is this ever a slow, agonizing process, at least the way I've been doing it. I know it's necessary because there are 3 layers of poorly prepped paint over top of the factory finish, so I want to get it all off. What are you guys doing to get the job done?
Re: Paint stripping an engine bay, how do you do it? [Re: DaytonaTurbo] #696572
05/12/10 09:34 PM
05/12/10 09:34 PM
A braided wire cup wheel on an angle grinder does an awesome job.
You have to be careful around holes so you don't oval them out and around edges (it hurts if it gets ahold of you!)
Cheap too! My angle grinder came from Harbor Freight and was $20.00 on sale. I bought 3 and keep a grinding wheel on one, wire cup wheel on one, and a cutoff wheel on another.
Here is the inner fender after:
Trust me, it was NASSTY!
Re: Paint stripping an engine bay, how do you do it? #696573
05/12/10 09:40 PM
05/12/10 09:40 PM
After paint/440 install:
Re: Paint stripping an engine bay, how do you do it? [Re: DaytonaTurbo] #696574
05/12/10 09:47 PM
05/12/10 09:47 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Easiest way sand blast.
Stripper is messy and sanding is messy and time consuming. But the wire wheel is a good middle ground.
Re: Paint stripping an engine bay, how do you do it? [Re: moparpollack] #696575
05/12/10 09:51 PM
05/12/10 09:51 PM
Manitoba, Canada
Manitoba, Canada
What I was doing today was using the liquid paint stripper to soften up the paint, then cleaning it off with the wire wheel. It works okay but I can't get into the corners very well with it where the inner fenders meet the firewall or the rad support.
I do have a handheld sandblaster, I tried it and it does work, but again, a very slow process.
Do those wire wheels with the nylon "wires" work better than the wheels with the braided steel wires?
Re: Paint stripping an engine bay, how do you do it? [Re: DaytonaTurbo] #696576
05/12/10 09:56 PM
05/12/10 09:56 PM
I do use a "spot blaster" for the corners and hard to get at areas.
There's lots of surface area so it takes a while.
Re: Paint stripping an engine bay, how do you do it? [Re: DaytonaTurbo] #696577
05/12/10 10:40 PM
05/12/10 10:40 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
paint striper and a pressure washer?
Re: Paint stripping an engine bay, how do you do it? [Re: DaytonaTurbo] #696578
05/12/10 11:56 PM
05/12/10 11:56 PM
minot north dakota
ledft79 Offline
ledft79  Offline
minot north dakota
I was wondering the same thing. All good ideas. Less work and better results than what I probably would have came up with. I also thank you.
DRIVE EM, DONT HIDE EM.
Re: Paint stripping an engine bay, how do you do it? #696579
05/12/10 11:56 PM
05/12/10 11:56 PM
CONNECTICUT
RoyceFlo73 Offline
RoyceFlo73  Offline
CONNECTICUT
I just did mine a couple weeks ago, I used aircraft skin remover and pretty much painted the entire bay one section at a time.
It would sit for 15-20 minutes and the paint would bubble pretty good. Then i used a high pressure attachment on a garden hose and most of it pealed off pretty good. I didn't have three coats to go through though.
Anyways, i did that and just used a wire wheel to clean the last bits of stubborn paint. You have to paint it on pretty thick though and DEFINATLY where gloves. I've been around a share of solvents and this stuff is nasty. I think i bought 2 or three cans of the stuff for like 11$ a can at autozone.
Re: Paint stripping an engine bay, how do you do it? [Re: Challenger 1] #696580
05/13/10 12:13 AM
05/13/10 12:13 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
That is what I did...some chemical stripper and blasted it off..was down to bare metal for about 75% of the engine bay after the first go, the rest took another coat (in a few spots)
On my Holden...the factory spot welds looked brand new!
Re: Paint stripping an engine bay, how do you do it? [Re: OzHemi] #696581
05/13/10 10:22 PM
05/13/10 10:22 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I used easy-off oven cleaner...Took multiple layers of paint off the engine bay the easy way...
Re: Paint stripping an engine bay, how do you do it? [Re: screamindriver] #696582
05/14/10 08:06 AM
05/14/10 08:06 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
brake fluid in an old windex bottle?
2017 Grand Cherokee Overland
Re: Paint stripping an engine bay, how do you do it? [Re: patrick] #696583
05/14/10 09:38 AM
05/14/10 09:38 AM
30 miles west of EuroDisney
fbernard Offline
fbernard  Offline
That's what I keep old brake fluid for. And an old paintbrush too (you don't want to reuse that brush for painting anything though).
If it works that well for the driver side frame rail, it can't fail for the inner fenders!!
Brush on, wait for 10 minutes, scrape off, brush again for the next layer if it stayed on. Will get the large flat areas clean in a hurry. You may use a heat gun to help the scraping but brake fluid alone is already pretty good...
Re: Paint stripping an engine bay, how do you do it? [Re: DaytonaTurbo] #696584
05/14/10 09:48 AM
05/14/10 09:48 AM
Jacksonville Florida
elitecustombody Offline
sandblasting works for me,it's the fastest method and I know I got every bit of any crust in corners and seams,but I'm sure other home remedies work too,just not as efficient and usually will take hours, also on small things if I don't want to get media or sand all over the place, I use Aircraft stripper in aerosol can,it can be purchased at any autoparts store
Re: Paint stripping an engine bay, how do you do it? [Re: elitecustombody] #696585
05/14/10 10:01 AM
05/14/10 10:01 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I used the 3m stripping dics for the open areas and then put sticky backed 80 grit on popsicle and wood paint stir sticks to get into the corners.
A dremel tool with the various wire tips is also goof for digging the crust out of the spot welds ect.
Re: Paint stripping an engine bay, how do you do it? [Re: elitecustombody] #696586
05/14/10 10:21 AM
05/14/10 10:21 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Aircraft paint remover, let it soak in...Go through with a spatula and get all the initial skin off, Then lay it on again and let it soak for about 30 minutes. Wear a mask when you do this please.
I follow through with my gasoline powered pressure washer which has a sand siphon attachment and let loose the 2500 psi on the engine bay. You'll finish quick. Just duct tape any holes from the other side of the firewall and cover any electrical terminals.
Blow through with an air compressor and start the wire brush on the metal. When you are done with all that and its shiny...lay down some WD-40 on it so it doesnt oxidize or you'll be with a wire brush again. Use MEK to strip off the WD40 and run your primer over it
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Paint stripping an engine bay, how do you do it? [Re: Pyper70] #696587
05/14/10 10:59 AM
05/14/10 10:59 AM
Cincinnati, Ohio
Cincinnati, Ohio
Skip the WD 40 and go straight to primer. Cost less and your get a better quicker job. My
Re: Paint stripping an engine bay, how do you do it? [Re: elitecustombody] #696588
05/14/10 11:03 AM
05/14/10 11:03 AM
Cincinnati, Ohio
Cincinnati, Ohio
Of course media blasting is best, but not always advisable if the car is not all the way stripped. Too many places for the abrasive to go without the car being stripped IMO.
Re: Paint stripping an engine bay, how do you do it? [Re: Challenger 1] #696589
05/14/10 11:13 AM
05/14/10 11:13 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I'd go for priming as well....Most people just aren't equipped as others. Was just giving an option
Re: Paint stripping an engine bay, how do you do it? [Re: Pyper70] #696590
05/14/10 12:55 PM
05/14/10 12:55 PM
Canada
DmanSRT71 Offline
DmanSRT71  Offline
Canada
I've never heard of a sand siphon attachment. Does this give a slurry of water and sand?
69 Road Runner 383/auto/N96 71 Demon 340/4 spd Would like to find a rust free Cuda body.
