Big-Block Engine to 727 Trans Bolts? #696555
05/12/10 09:00 PM
05/12/10 09:00 PM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
Last week I noticed a weird sound coming from the engine bay when I revved the engine an upon closer inspection I saw the trans was loose. Every bolt holding the engine to the trans was finger tight and the bottom-most two are now missing. I tightened the remaining four. Does anybody know where I can get the bottom-most nuts and bolts or the correct lengths and sizes?
Re: Big-Block Engine to 727 Trans Bolts? [Re: bordin34] #696556
05/12/10 09:14 PM
05/12/10 09:14 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Hoover auto parts has them on their website iirc.
You could always find them at your local junkyard too....
Re: Big-Block Engine to 727 Trans Bolts? [Re: bordin34] #696557
05/12/10 10:35 PM
05/12/10 10:35 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
7/16 coarse thread
Re: Big-Block Engine to 727 Trans Bolts? [Re: bordin34] #696558
05/12/10 11:52 PM
05/12/10 11:52 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Dan:
I have the "correct" original style captive washer bolts you need if you want to pick them up. Or you can also still get them from the dealer. Both styles are still available as bolts which are very similar are still used on late model vehicles.
Check your PM box. I left you a msg.
MB
Re: Big-Block Engine to 727 Trans Bolts? [Re: HPMike] #696559
05/13/10 12:13 AM
05/13/10 12:13 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
I absolutely LOVE those bolts with the captured washers. I use 'em on intake manifolds toooo.
