69 383-2 compression ratio? #695435
05/11/10 11:19 PM
05/11/10 11:19 PM
southern Idaho
moparcyco Offline OP
southern Idaho
Hello just wondering if someone Knows the factory compression ratio for a 69 383 2 barrell.Stock bore heads etc.has steel shim head gasket.What were these rated at?Thanks guys
Re: 69 383-2 compression ratio? [Re: moparcyco] #695436
05/12/10 06:13 AM
05/12/10 06:13 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
My source shows 9.2-1(blueprint spec, in reality it's maybe .5 lower). 290hp@4400 and 390ftlbs@2800 Dave
Re: 69 383-2 compression ratio? [Re: quickd100] #695437
05/12/10 07:14 PM
05/12/10 07:14 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..did 2 bbl. engines have different pistons than the 4bbl?(RR)
Re: 69 383-2 compression ratio? [Re: can.al] #695438
05/13/10 06:10 AM
05/13/10 06:10 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Yes; slightly different compression height. They used the same head, same head gasket. dave
Re: 69 383-2 compression ratio? [Re: quickd100] #695439
05/13/10 11:40 AM
05/13/10 11:40 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
IIRC the 383 2v had dished pistons and the 4v had flat tops.
Re: 69 383-2 compression ratio? [Re: stumpy] #695440
05/13/10 12:25 PM
05/13/10 12:25 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I have a 69 383 2bbl piston sitting here next to me , it's the exact same compression height as the 69 383 4 bbl , 330 and 335HP , but with a DISH .
Re: 69 383-2 compression ratio? [Re: JohnRR] #695441
05/13/10 01:23 PM
05/13/10 01:23 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I stand corrected, been a few years since I had one. Thanks John . dave
