'68 B-Body front Drum 2 Disc parts info needed...?'s #69539
06/07/08 09:55 PM
06/07/08 09:55 PM
Mansfield,Ohio
moparrulzzz Offline OP
Mansfield,Ohio
I am starting to compare prices to do my brake swap. I am using the 73-76 A body spindles with the slider caliper brackets.
I need to know if I am on the right track as far as parts...
Inner/outer Bearings....'80 Volare'
Calipers.....'80 Volare'(to rear mount)
Rotors....'78 Cordoba
Do I order the L&R calipers as normal and just swap sides??
I am also going with manual brakes..Got a M/C from ebooger, he thinks it is a 1 1/16 bore. Will this work with this set-up??
using a proportioning valve from the same '76 A body..
Thnx Chuck
Re: '68 B-Body front Drum 2 Disc parts info needed...?'s [Re: moparrulzzz] #69540
06/08/08 09:10 AM
06/08/08 09:10 AM
BDW Offline
BDW  Offline
I bought eveything for my Challenger at local Advanced Auto. If you order online, you'll get free shipping.
raybestos w/pad RC4103/4 $36.00
78 charger (slider)
outer bearing BR2 $6.00
78 charger
wearever rotor YH141132 $52.00
78 charger
dorfman banjo bolt 13938 $5.00
inner wheel bearing BR17 $8.00
77 charger
inner seal 19500 $2.00
77 charger
raybestos hose 4536755 $15.00
76 duster
Re: '68 B-Body front Drum 2 Disc parts info needed...?'s [Re: BDW] #69541
06/08/08 05:16 PM
06/08/08 05:16 PM
Mansfield,Ohio
Mansfield,Ohio
Are those calipers rear mount? I need rear mount with the sway bar issues??
Chuck
Re: '68 B-Body front Drum 2 Disc parts info needed...?'s [Re: moparrulzzz] #69542
06/09/08 07:09 PM
06/09/08 07:09 PM
BDW Offline
BDW  Offline
Mine are front mount (Challenger). But from everything I've read, you just swap the spindles from side to side to rear mount the calipers.
Parts list should be the same.
