manual 4-speed trans #695109
05/11/10 04:34 PM
05/11/10 04:34 PM
Ohio USA
danspony Offline OP
danspony  Offline OP
Ohio USA
Can anyone tell me what year this trans is and anything else related-input shaft is 23 spline
casting number on case is- C95639U on extension housing- C95658-L and there is also a 3-16 stamped in the case. Thnaks
Re: manual 4-speed trans [Re: danspony] #695110
05/12/10 09:35 AM
05/12/10 09:35 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Casting numbers are pretty much USELESS to identify the trans , what is STAMPED on the machined pad on the right side of the trans .
Re: manual 4-speed trans [Re: JohnRR] #695111
05/12/10 09:43 AM
05/12/10 09:43 AM
IMGTX Offline
IMGTX  Offline
This picture helps.
