Hughes bananna grooved shafts #694780
05/11/10 09:14 AM
05/11/10 09:14 AM
Finally a HUSKER again
Moparnut426 Offline OP
I have harlan sharp rockers, and Wanted the heavy duty thick shafts, and have heard that hughes are nice. I bought a set not knowing that all of hughes shafts are bananna grooved. Are these grooves gonna mess with my roller bearings in my rockers? Has anyone on here had any experiance with this?
Kasey
Re: Hughes bananna grooved shafts [Re: Moparnut426] #694781
05/11/10 09:33 AM
05/11/10 09:33 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
my understanding is the shafts for the HS rockers are a special hardness to hold up with the bearings I would be getting some shafts from HS
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Hughes bananna grooved shafts [Re: dusturbd340W5] #694782
05/11/10 09:35 AM
05/11/10 09:35 AM
I was also told the Hughes are just as hard.
Re: Hughes bananna grooved shafts [Re: Moparnut426] #694783
05/11/10 09:45 AM
05/11/10 09:45 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I think Harland Sharp shafts are hard chromed. (different than bumper chrome)
I'd check with Dave first. I don't think his will work with needle bearings.
Re: Hughes bananna grooved shafts [Re: S/ST 3040] #694784
05/11/10 10:02 AM
05/11/10 10:02 AM
I was going to just turn them over, but I was afraid of them oiling. Ill Just sell the Hughes shafts on here, and get the Sharp shafts.
Kasey
Re: Hughes bananna grooved shafts [Re: Moparnut426] #694785
05/11/10 11:20 AM
05/11/10 11:20 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i don't think you'd want banana groves with roller bearings, . i believe the harland sharps have an induction hardened shaft specific for their rockers.
Re: Hughes bananna grooved shafts [Re: lewtot184] #694786
05/11/10 11:36 AM
05/11/10 11:36 AM
Yep, im ordering them today, NOON.
Summit has them for 195.
Ill try to sell my hughes I guess.
Kasey
Re: Hughes bananna grooved shafts [Re: S/ST 3040] #694787
05/11/10 12:16 PM
05/11/10 12:16 PM
Well great, They are on Back order and I wont see them till JUNE!!
Does anyone on here have a set of small block Harland sharp shafts they woulds want to sell??
Kasey
Re: Hughes bananna grooved shafts [Re: Moparnut426] #694788
05/11/10 01:36 PM
05/11/10 01:36 PM
Kissimmee Fl.
Kissimmee Fl.
did you try HS or just summit
Re: Hughes bananna grooved shafts [Re: dusturbd340W5] #694789
05/11/10 03:32 PM
05/11/10 03:32 PM
JUST SUMMIT.
They are about $20 bucks cheaper.
Re: Hughes bananna grooved shafts [Re: Moparnut426] #694790
05/11/10 05:41 PM
05/11/10 05:41 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
It may sound crazy, but you can make a set. I bought Thompson rod and had a set made. It is hardened (50-53)on the outside and can be drilled on the inside. One of the reasons I went this direction was that 1) I get a thicker shaft like a Harland (gun barrel) 2) Correct diameter for my rockers. The needle bearing in my rockers are actually made for a .875 shaft, stock shafts are .873. 3) Cost, I have less than $100 in them. The rod is available at McMaster Carr and both shafts together were less than $50 delivered. It works out at least on the big block that there is a ready made rod the right length maybe an 1/8 short. So I guess this is an option if you have machine shop close by that you trust.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Hughes bananna grooved shafts [Re: Moparnut426] #694791
05/11/10 06:48 PM
05/11/10 06:48 PM
JUST SUMMIT.
didn't you get shafts with the rockers? and of not, why?
Re: Hughes bananna grooved shafts #694792
05/11/10 09:00 PM
05/11/10 09:00 PM
A friend of mine sold them to me, he used them on his street engine for a summer, then switch to a big block, and when he sold the engine he knew I was looking for a set, he sold them to me, and he had some crane iron rockers, but no spare shafts. I didnt know there was much difference until now or I would have boughten his when I got these. These were on a hydraulic flat cam. The 484 purple shaft cam to be exact so they are in great shape.
Kasey
