AAR hood #694552
05/10/10 10:29 PM
05/10/10 10:29 PM
desomod Offline OP
desomod  Offline OP
I am doing a '70 Hemi Cuda pro touring deal and am trying to decide on what hood I want to use. The Shaker is awesome but so is the price by the time you are done.
I am thinking of going with the AAR style. Do you guys have any opinion (of course you do!) on who has the best fitting product out there?
Thanks.
Re: AAR hood [Re: desomod] #694553
05/11/10 06:06 PM
05/11/10 06:06 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
Several years ago the Year One hood actually fit pretty good.
Re: AAR hood [Re: Paul Jacobs] #694554
05/11/10 08:30 PM
05/11/10 08:30 PM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
Paul's got a used one .
Re: AAR hood [Re: desomod] #694555
05/12/10 02:28 PM
05/12/10 02:28 PM
Newfoundland
Crocker Offline
Crocker  Offline
Newfoundland
I'm also going the 70 cuda pro touring route with a 472 hemi and an AAR hood. I got mine 20% off through year one ($550 i think) shipping was more than the hood but I'm in Newfoundland canada. The fit was nicer than most originals i seen but not perfect... i adjusted it as best as possible but it had a little more bow than the fenders...Don't really matter to me, but if you're particular and want it straight like a steel hood you may have to work it a bit . I looked at couple other suppliers but I posted the question here about them and did not get positive responses (long waits, poor communication etc)
Re: AAR hood [Re: Crocker] #694556
05/12/10 06:41 PM
05/12/10 06:41 PM
desomod Offline OP
desomod  Offline OP
Were you able to work the hood to better fit the fenders? I know the original AAR and T/A hoods always had a nasty bow in them that was nearly impossible to remove.
Re: AAR hood [Re: desomod] #694557
05/12/10 06:45 PM
05/12/10 06:45 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Not always. It is common with cars that saw a lot of heat from sunshine.
Re: AAR hood [Re: Alaskan_TA] #694558
05/12/10 08:28 PM
05/12/10 08:28 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Penstar had some AAR hoods at Farmington last weekend. They looked pretty good, and the guy said they had extra steel reinforcement in the hinge area. Anybody used one on a car?
Re: AAR hood [Re: desomod] #694559
05/13/10 09:04 AM
05/13/10 09:04 AM
Newfoundland
Crocker Offline
Crocker  Offline
Newfoundland
I never tried to tweak the hood at all. I just used the adjustment at the hinges and at the front rubber stops to make fit as best as possible. There's not much to these hoods. They are light as a feather and thin fibreglass, so I was nervous about tweaking it.
On another note, because of the fresh air intake and the cowl vent, the car runs cooler than with the rally hood... bonus!
Re: AAR hood [Re: Crocker] #694560
05/14/10 12:00 PM
05/14/10 12:00 PM
desomod Offline OP
desomod  Offline OP
Thanks for the input everyone.
I too have a T/A (original) and I fight the poor fitting, mid fender line all the time. I have seen that problem alot with the factory hoods, perhaps because they did spend alot of time in the sun.
I looked in my Year One catalog and they are now over $700 bones. I know they usualy have the discount cards going out so I guess I will have to wait for one.
Any other source for the AAR style hood other then Y.O. that I should look at??
Re: AAR hood [Re: desomod] #694561
05/14/10 12:49 PM
05/14/10 12:49 PM
NY usa
540challenger Offline
NY usa
I just got my T/a hood in Dec of 09 from year one. If you enter the moparts15 code plus get some buddies together to hit $1000 order. i think the hood cost around $570 for shipped to my door.
Re: AAR hood [Re: 540challenger] #694562
05/14/10 01:14 PM
05/14/10 01:14 PM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
Just a little input about the stock AAR hood fit. My friend worked at the factory when they were installing the AAR hoods on the cars. He said that some had so much bow in them that they had to set the front and rear corners low just to close up the gap in the center. It wasn't the sun causing the problem the hoods were bad straight from the supplier. Just my
Re: AAR hood [Re: FY1TA] #694563
05/18/10 03:07 AM
05/18/10 03:07 AM
East Coast, NJ
fig426 Offline
fig426  Offline
East Coast, NJ
Gary has 2
Chris from New Jersey
Re: AAR hood [Re: maximus] #694564
05/18/10 03:40 AM
05/18/10 03:40 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
I'm more inclined to believe the hoods were a problem from the start seeing how crude they were made. I have two original T/A hoods with the same "bow" problem, I sliced in front of the hinge support plate and bowed the hood down and reglassed it for a much better fit.
Re: AAR hood [Re: HEMICUDA] #694565
05/18/10 09:12 AM
05/18/10 09:12 AM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
My hood was from Year One and was decent, but had the bow too. My body guy recently cut the hood and fixed the bow. He also lengthened the front of the hood to close some of the gap between it and the header panel.
