Header gaskets w/ stock manifolds #694320
05/10/10 06:31 PM
05/10/10 06:31 PM
Scottsdale, AZ
K
kenz Online content OP
kenz  Online Content OP
K
Scottsdale, AZ
Is it okay to use header gaskets with stock exhaust manifolds? This is on a 318 w/ 340 manifolds. I have a set of Mr Gasket header gaskets. Should I use them or buy the stock exhaust gaskets?
Thanks,
ken
Mopars Unlimited of Arizona
www.moparsaz.com
Re: Header gaskets w/ stock manifolds [Re: kenz] #694321
05/10/10 07:12 PM
05/10/10 07:12 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Put them on
I have a 440 going together with stock manifolds...using a gasket
Re: Header gaskets w/ stock manifolds [Re: roadhazard] #694322
05/10/10 07:40 PM
05/10/10 07:40 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Use them
Re: Header gaskets w/ stock manifolds [Re: kenz] #694323
05/10/10 11:50 PM
05/10/10 11:50 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Why use gaskets at all? In many cases no gasket was used. if the mating surfaces are flat and true, you don't need one.
Re: Header gaskets w/ stock manifolds [Re: Kern Dog] #694324
05/11/10 07:57 AM
05/11/10 07:57 AM
scratchnfotraction Offline
I never run gaskets on the head with mannys
I do make sure they are milled flat and use the copper rtv and bolt them on,let cure over night
headers..well thats another story,IMHO
Re: Header gaskets w/ stock manifolds [Re: Kern Dog] #694325
05/11/10 09:08 AM
05/11/10 09:08 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I've had a few leaking gaskets on manifolds over the years (gaskets that other folks have installed) and the manifolds don't seem to seal up after removing the gasket, and they are visibly pitted from the gaskets (those 'quilted' metal gaskets, anyway).
Sometimes 80-grit on a DA saved them, sometimes not.
Try them without gaskets, and if they don't leak run 'em as-is.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: Header gaskets w/ stock manifolds [Re: scratchnfotraction] #694326
05/11/10 09:08 AM
05/11/10 09:08 AM
Wisconsin
wkroncke17 Offline
wkroncke17  Offline
Wisconsin
I posted this same thing not long ago, I was told to use remflex. I bought a pair, not installed yet.
Re: Header gaskets w/ stock manifolds [Re: wkroncke17] #694327
05/11/10 11:06 AM
05/11/10 11:06 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Remflex... Never heard of it... Wait, is that the series of thin aluminum gaskets several layers deep?
Re: Header gaskets w/ stock manifolds [Re: Kern Dog] #694328
05/11/10 11:34 AM
05/11/10 11:34 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
no they are graphite
I'll never buy another brand of exhaust gaskets...
www.remflex.com
Re: Header gaskets w/ stock manifolds [Re: kenz] #694329
05/11/10 02:48 PM
05/11/10 02:48 PM
Scottsdale, AZ
K
K
Scottsdale, AZ
Thanks for the replies. I think I'll use the header gaskets since I have them. It's easy enough to change them if I have a problem down the road.
Thanks again,
Ken
