removing lock style wheel nuts,without the lock socket? #694252
05/10/10 05:16 PM
05/10/10 05:16 PM
Usa
10secchallenger Offline OP
Usa
i have a car with the lock style lugnuts and no special lock socket to remove them with.so is there any other way to get this nuts off?so i can just install regular nuts?
Re: removing lock style wheel nuts,without the lock socket? [Re: 10secchallenger] #694253
05/10/10 05:32 PM
05/10/10 05:32 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
Take an impact socket just larger than the lug and hammer it over the lug and use an impact wrench to loosen it.
Re: removing lock style wheel nuts,without the lock socket? [Re: RV2] #694254
05/10/10 05:40 PM
05/10/10 05:40 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
if that doesn work snap on ,mac and even sears has a special socket for removeing the lock nuts
Re: removing lock style wheel nuts,without the lock socket? [Re: RV2] #694255
05/10/10 05:44 PM
05/10/10 05:44 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
easy way to do it
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: removing lock style wheel nuts,without the lock socket? [Re: deansrr] #694256
05/10/10 06:08 PM
05/10/10 06:08 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Use a punch to knock the center pin in and use either a 3/8" or 1/2" extension, which ever will fit, to take them off. Did it a lot while working at a used car lot.
Re: removing lock style wheel nuts,without the lock socket? [Re: deansrr] #694257
05/10/10 06:43 PM
05/10/10 06:43 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
easy way to do it
x 2, done it a ton of times.
Re: removing lock style wheel nuts,without the lock socket? [Re: OzHemi] #694258
05/10/10 06:47 PM
05/10/10 06:47 PM
fury4speed Offline
fury4speed  Offline
Hammer a old socket on it and it should come off.
Re: removing lock style wheel nuts,without the lock socket? [Re: fury4speed] #694259
05/10/10 07:20 PM
05/10/10 07:20 PM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
An impact socket ? .... a 6 point ??
NEVER had any luck with that .. but I have used a 12 point with muchO success.
Re: removing lock style wheel nuts,without the lock socket? [Re: BeEtLeJuIcE !] #694260
05/10/10 09:11 PM
05/10/10 09:11 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Easy to hard
Head over to a used car lot that has been there for decades. They probably have a coffee can full of keys.
Go to a tire shop (not a chain store, the local guys). They have the special tool that works pretty good.
Buy the special tool yourself
Beat on a socket
Weld on a nut
Re: removing lock style wheel nuts,without the lock soc [Re: RodStRace] #694261
05/10/10 09:23 PM
05/10/10 09:23 PM
Southaven, MS
BossRide Offline
BossRide  Offline
Southaven, MS
While in high school a buddy had a few sets of wheels stolen from his car. Frustrated, he had four different locking lugs installed. They took his wheels yet again, and lined the lug nuts up neatly on the curb... apparently they are easy to remove. Good luck!
The Blue Goose
My instagram: Bossride
Re: removing lock style wheel nuts,without the lock socket? [Re: Dougsmopars] #694262
05/10/10 09:44 PM
05/10/10 09:44 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Also available on E-Bagger..
http://cgi.ebay.com/ebaymotors/2-EMERGEN...omotiveQ5fTools
Just my $0.01...
Re: removing lock style wheel nuts,update. [Re: Sinitro] #694263
05/11/10 08:25 PM
05/11/10 08:25 PM
Usa
Usa
well i tried pounding on a socket, 12 pt and 6 pt.,that didn't work.i went to sears and bought the wheel lock nut remover socket set.still no luck it appears the nut is hardend. and the fluted end won't grip the nut.i really don't want to weld a nut on on this since it has alumnium wheels.any other ideas?i may try the tire shop idea on my day off.if there any other ideas please post them. thanks for all the repies.
Re: removing lock style wheel nuts,update. [Re: 10secchallenger] #694264
05/11/10 09:36 PM
05/11/10 09:36 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Most often a 12 point socket will work. I've taken keys that are close and ground the non fitting portion off. At times I've had to air chisel them, catch a notch in the grove and walk it around. Also smack inward towards the wheel with a large hammer,many times this will loosen it enough to use the previous socket idea mentioned. I've had to torch them off as well. Covering the surface of the wheel with wheel bearing grease before torching will protect the finish of the wheel.
Good luck Doug
Re: removing lock style wheel nuts,update. [Re: 10secchallenger] #694265
05/11/10 09:40 PM
05/11/10 09:40 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I have had a few stubborn ones, but using a larger has done it in the past. I use like a 10" extension on the socket (to keep the hammer away from the wheel) then use a small sledge to it on, instead of just a normal hammer. Not only does the added weight help to pound the socket down and on, it also helps shock (as mentioned) the lock itself to help loosen it some..
Re: removing lock style wheel nuts,update. [Re: OzHemi] #694266
05/11/10 09:58 PM
05/11/10 09:58 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
As I said earlier. Take a punch and drive the center pin in. There is enough room between the stud and lock to do this. Then take a square 3/8 drive short extension and use it as a key. I have done a bunch of lock lug removals this way while working on used cars.
Re: removing lock style wheel nuts,update. [Re: stumpy] #694267
05/11/10 11:23 PM
05/11/10 11:23 PM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
Kinda makes you wonder why you would bother buying lock nuts at all.
Re: removing lock style wheel nuts,update. [Re: moparcanuk] #694268
05/11/10 11:38 PM
05/11/10 11:38 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Drive a close sized socket on and use an impact on it.
I want my fair share
Re: removing lock style wheel nuts,update. [Re: SomeCarGuy] #694269
05/12/10 07:56 AM
05/12/10 07:56 AM
Middle of the mitten
69DodgeCharger Offline
If all else fails you can carefully use a cut off wheel and slit the outer shell of the lug nut on both sides and then knock it off with a punch. If you do this make sure you cover the wheel and anything else important from the sparks the cut off wheel throws. I like to make one cut parallel to the rim on two opposite sides of the nut where it meets the wheel and then make my perpendicular cuts/slits that run along the length of the lug nut shell that way you kep the cut off wheel away from the rim itself as much as possible. This is a pain but I've done it before.
Re: removing lock style wheel nuts,update. [Re: 69DodgeCharger] #694270
05/12/10 08:39 AM
05/12/10 08:39 AM
Orange Park, FL
MRHWS Offline
MRHWS  Offline
Orange Park, FL
If you have a Discount Tire store in your area, they have a master set to remove any brand of lock.
1973 Charger SE 1974 Charger Rallye 440 Aztec 2008 Charger SRT8
Re: removing lock style wheel nuts,update. [Re: MRHWS] #694271
05/12/10 11:27 AM
05/12/10 11:27 AM
grande prairie , ab , canada
68notch Offline
68notch  Offline
i just welded on a nut , kept the rim wet , then spun off with an impact wrench
theres nothing as permanent as a temporary fix 70 super bee 79 red express 67 fargo 8o aspen rt
