Need to replace the upper a-arm mounting bracket on 69 Super Bee due to rust. Have an entire front framerail section including the shock tower and want to know if it would be easier/safer to remove only the bracket itself and re-weld (two large rectangular welds) or drill out the spotwelds and the welded tab on the frame and replace the entire shock tower. Any tips appreciated!
Thanks Moparts
Cole
