Stumble from my 850 Mighty Demon? #69347
06/07/08 07:32 PM
06/07/08 07:32 PM
Maryland
dduster73 Offline OP
Maryland
73 Duster 440/4speed 9.7 compression rebuilt engine 1 3/4 TTI headers. Stock Holley Street Dominator intake.Comp Cams XE 285 HL hydraulic camshaft 285-297 241/247@.050 545/545 @1.5 rockers.850 Demon carb has 72/80 jets,31 squirters and 4.5 powervalve with 8.5" of vaccuum @800 rpm.Had a 6.5 power valve but no change.Car will stumble @ part throttle when pulling away from a light.Seems to do this at anything under 3000 rpm.Any help appreciated. Thanks ,Dave
Re: Stumble from my 850 Mighty Demon? [Re: dduster73] #69348
06/07/08 07:49 PM
06/07/08 07:49 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I just checked the Demon web sight and found that a stock 850 MD comes with 85/93 jets. Your 72/80 is almost what a 650 Speed Demon comes stock with. Have you checked your plugs to see if you are lean?
Have you tried a 035 squirter?
Have you checked to see if fuel comes out of the squirter AS SOON as the throttle moves?
Re: Stumble from my 850 Mighty Demon? [Re: dduster73] #69349
06/07/08 07:55 PM
06/07/08 07:55 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
your driving this car on the street?
probably not built for the street and stop and go....no?
eehh?
Re: Stumble from my 850 Mighty Demon? [Re: mark7171] #69350
06/07/08 08:05 PM
06/07/08 08:05 PM
Maryland
Maryland
Yes this is a mild street car.Runs on pump gas.The 850 Mighty Demon came out of the box with 80/88 jets, but the plugs were black so i jetted it down.If i just nail it it has a bog.No black smoke out the exhaust.Dave
Re: Stumble from my 850 Mighty Demon? [Re: dduster73] #69351
06/07/08 08:13 PM
06/07/08 08:13 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
your gonna get rolled.
whats your timming like? itial+mechanical+vacuum...
let me guess ... no vacuum advance....
you have a race car. the transitition circuit probably wont cover the demand, and it will be a WOT machine.
tim + eric say- GREAT JOB !
Re: Stumble from my 850 Mighty Demon? [Re: dduster73] #69352
06/07/08 08:16 PM
06/07/08 08:16 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
that is not street car specs. i find this makes me laugh.
Re: Stumble from my 850 Mighty Demon? [Re: mark7171] #69353
06/07/08 08:20 PM
06/07/08 08:20 PM
Kirkland, Washington
Pacnorthcuda Offline
Huh????? What part of his specs scream "race car only" to you???? While the cam is a little larger than I prefer on a street car, I have run bigger. And with less vacuum (6.5")
Re: Stumble from my 850 Mighty Demon? [Re: dduster73] #69354
06/07/08 08:24 PM
06/07/08 08:24 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
""The 850 Mighty Demon came out of the box with 80/88 jets""
I just checked again and the 850 "AD" Mighty Demon comes with 80/88 jets and the 850 Mighty Demon comes with the 85/93 jets.
Does this carb have annular boosters?
Is this carb a blower carb by chance?
I found this to be a #5563020GC 850 Mighty Demon Annular Mechanical Secondary carb. This helps explain the smaller jetting. The annulars pull alot more fuel thru smaller jets. If your plugs look good, then I would try raising the squirter size .
Re: youre right it could be? [Re: YO7_A66] #69355
06/08/08 12:09 AM
06/08/08 12:09 AM
ILL
mark7171 Offline
mark7171  Offline
ILL
my comments are a little raw. your engine that you built should be streetable, because as they say " it runs on pump gas " .
people do some strange things to there cars.
what package did you try to come close to ... or in between ?
look at holleys systemax I,II. or edelbrocks performer, torquer II, or RPM. OR the mopar performance packages in the back of the jobber MP catalogs. mp's suggestions goes to 8.90's i believe...if you still cant come close look at Trickflo's twisted wedge package offerings.
Re: youre right it could be? [Re: mark7171] #69356
06/08/08 07:40 AM
06/08/08 07:40 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Get your initial timing around 20 and your total around 36. Make sure you have no vacuum leaks. I run a similar combination and it responds real good on the street. I use the 750 Mighty Demon, though.
Re: youre right it could be? [Re: bobby66] #69357
06/08/08 12:46 PM
06/08/08 12:46 PM
Maryland
Maryland
Yes it has annular boosters.Will try to add more inital timing its at 15* now. Then i'll try 35&36 squirters.If that makes no difference will go back to the 80/86 jets. The cam was chosen by Comp Cams reccomendation.Thanks to all for the advice. Dave
Re: youre right it could be? [Re: dduster73] #69358
06/08/08 01:48 PM
06/08/08 01:48 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I think the timing is your main issue.
15 is waaaaaaayyyyyyy not enough for that cam duration, and that compression.
Your inital should be more like 22.
If you can set it up for 22-24 initial with 35 total, all in by 2800, I think you will be amazed at the difference
FWIW...I have less cam (242@50) with more comp (10.7:1) and I run 24 intial.
Re: youre right it could be? [Re: dduster73] #69359
06/08/08 09:03 PM
06/08/08 09:03 PM
Alberta, Can
JUST_N_TIME Offline
JUST_N_TIME  Offline
Alberta, Can
make the changes Dave571 said and change jetting to 76/84 w/35 squirters. should make a big difference.
Re: youre right it could be? [Re: JUST_N_TIME] #69360
06/08/08 09:26 PM
06/08/08 09:26 PM
Maryland
Maryland
Okay I'll try more initial timing and go back to bigger squirters. Thanks again for all the help. Dave
Re: youre right it could be? [Re: dduster73] #69361
06/08/08 10:12 PM
06/08/08 10:12 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
if its NOT timming and IS the carb...it will be a lean problem. cover it up with a longer pump shot. it will deliver the fuel its not pulling for itself. get you past and on to going fast. a smaller squirter, or larger 50cc pump , can accomplish this as well as bumping the pump cam around till it lasts longer.
Re: Stumble from my 850 Mighty Demon? [Re: dduster73] #69362
06/09/08 12:37 AM
06/09/08 12:37 AM
organ
maximum entropy Offline
organ
mighty demons are calibrated for larger cams. your cam should be big enough for that carb to work properly. every demon carb i've ever worked on has been full of metal chips from manufacture. in the main wells, everywhere. first you need to make sure that thing is absolutely clean. if it's mainly street driven and the plugs are black, it's most likely idle mixture. that carb does not have an intermediate circuit. make sure your float level is good. does your carb have idle ez? what kind of torque converter do you have? mighty demons are almost impossible to tune if your stall speed isn't high enough.
Re: Stumble from my 850 Mighty Demon? [Re: maximum entropy] #69363
06/09/08 06:22 PM
06/09/08 06:22 PM
Maryland
Maryland
The car is a manual transmission.There is a screw where the air cleaner stud goes, and it did come with an addendum paper work on the idle ez, but adjusting the center screw does not make any difference.I adjusted the idle settings using a vaccumm gauge for highest vaccumm.I adjusted the float level to the middle of the site glass.When i jetted it down i pulled the bowls and metering blocks off and it was very clean.I will try the suggestions one at a time when i get back to the garage. Thanks again, Dave
Re: Stumble from my 850 Mighty Demon? [Re: dduster73] #69364
06/09/08 11:16 PM
06/09/08 11:16 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
A friend just installed a mighty demon on his Olds race car.. His carb came with the wrong jets and when he called Barry Grant, he was told the specs were incorrect.. Might want to call yourself....
Re: Stumble from my 850 Mighty Demon? [Re: minivan] #69365
06/10/13 11:18 PM
06/10/13 11:18 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
I just put a mighty demon on my 440 with lumpy cam, Edelbrock Performer RPM intake, 1 3/4 headers, MP electronic ignition, 4 spd car,
The previous owner took out the primary power valve and blocked it, secondary also blocked. The carb has 86 primary jets,88 secondary. It doesnt run bad, but is running rick just driving normally. The plugs are dark tan, is there alot to gain by putting in the PV and dropping the jets down 8 or so sizes?
