62 Valiant?? #693294
05/09/10 05:33 PM
05/09/10 05:33 PM
Iowa
76dodgeboy Offline OP
Iowa
My brother in law has a 62 Valiant and we've been going back and forth on what powerplant to put in it. Just to put an LA318 requires ditching the heaterbox and other cutting. It finally came to me last night. A 3.9 V6 5spd from a Dakota. Most likely a magnum. What has to be taken from the doner vehicle and how hard would it be to wire it to the car if we can find a doner cheap enough. Thanks
Re: 62 Valiant?? [Re: 76dodgeboy] #693295
05/09/10 05:50 PM
05/09/10 05:50 PM
Coronado, CA
go-fish Offline
go-fish  Offline
Coronado, CA
I would have voted for a CRD out of a Liberty or a TDI from a VW. Diesel Power!
70 'cuda: ProCharged 408, Tremec 5 speed, S60,triangulated 4 link, Hydroboost and Wilwoods
Re: 62 Valiant?? [Re: 76dodgeboy] #693296
05/09/10 08:44 PM
05/09/10 08:44 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Whats wrong with another slant 6? You can get some pretty good kick out of them with a little work, and even upgraded would likely be cheaper when your all done then a 3.9 swap will be.
To put a 3.9 in there, you will need at least, the motor, trans, wiring, computer, fuel tank (or at least the proper pressure pump), motor mounts, exhaust, and probably a rad.
Then, the exhaust manifolds might not fit in the car (they are rear dump), the steering column may not clear the motor, and you will likely have to modify the firewall and trans mount areas. I suspect the 5 speed shifter is going to be in the dash as well, they are built into the top of the trans (like a granny gear 4 speed). A 3.9 motor mounts are at the center of the block and the 225 are more towards the front, I have to wonder what your going to have to do with the K member. A 3.9 is as wide as a la 318, and only 4" shorter. Do some measuring. Gene
Re: 62 Valiant?? [Re: poorboy] #693297
05/09/10 11:52 PM
05/09/10 11:52 PM
Coronado, CA
go-fish Offline
go-fish  Offline
Coronado, CA
Yep, realistically a slant six is the best bet. There is alot of power that can be had in a /6.
Try taking a look at Clifford Perfomance's site. Turbo /6?
Re: 62 Valiant?? [Re: poorboy] #693298
05/10/10 12:01 AM
05/10/10 12:01 AM
Iowa
Iowa
Fuel probably wont fit. The slant runs thats in it. The 3.9 will have more power than a slant in stock form especially a Magnum. Plus its not cheap to hop up a slant unless you find bargins witch are getting scarce. The 3.9 can be mounted forward some. People have installed V8s in them so it would be slightly easier with a V6 and rear dump manifols would imo would be best. The shifter lever can be modified to fit. I think a wrecked Dakota can be had for $350 or less and thats cheaper than a 390 Holley 4bbl so price wise is a very gray area do to not knowing what a wrecked truck can be had for and I think it would be a great gas mizing cruiser
Re: 62 Valiant?? [Re: 76dodgeboy] #693299
05/10/10 12:27 AM
05/10/10 12:27 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The 90 Dakota I have with the 3.9 5 speed got 22-24 mpg on the highway at the speed limit, and dropped if I went much faster.
Finding mag 3.9 5 speeds around here would be a challenge with anything less then 200k miles, then they would probably want $1,000 for a beat to death one. Hope you rate better in your area. Gene
Re: 62 Valiant?? [Re: poorboy] #693300
05/10/10 01:02 AM
05/10/10 01:02 AM
Iowa
Iowa
$1000 is still cheaper than building up a slant 6. A new 4bbl Ofenhouser intake is $240 a 390 cfm carb is $363 Clifford header is $359, 4bbl $289, Hyperpak 4bbl $469 and cam is $399.
Re: 62 Valiant?? [Re: 76dodgeboy] #693301
05/10/10 08:32 PM
05/10/10 08:32 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Not trying to argue, but after you dress up the 225, you will have a respectable motor that bolts into your car. When you spend the same money on the 3.9, you still have to make it fit in the car. Just saying.... Wonder what the power numbers look like between the dressed up /6 and the box stock mag 3.9?
Us Mopar guys never were much worried about doing things the simple way, it was always the final outcome we were concerned about. Swap in the 3.9, take a bunch of pictures, write up the "how to" and show us the track results. We are all waiting.
Gene
Re: 62 Valiant?? [Re: poorboy] #693302
05/11/10 12:21 AM
05/11/10 12:21 AM
Iowa
Iowa
Im not trying to argue either. Car dont belong to me, its my brother in laws and he is 17 and dont make squat.
With the slant six introduced in 1960 in two versions, a 101 hp, 170 cu.in and a 145hp, 225 cu. in. version, the slant six built its reputation for performance and reliability.
Hyper-Pak specs:
•Overhead valve. Cast iron block.
•Compression ratio: 11.5:1 (225), 10.5:1 (170)
•Brake hp: 195 at 5200 rpm (225), 148 (170)
The Magnum versions, with multiple-port injection, were rated at 180 hp. Torque jumped from 195 to 220 lb-ft as well
You can get a bigger trottle body and injectors but Im sure he can find a Dakota for Under $600 and the weight difference is Valiant 2750# and a regular cab shortbed Dakota is 3042#. Wich would improve milage imo. He might not ever do it so dont plan on a build post.Plus he dont have the skills needed but I think I might If he does go through with it Ill deff post about it.
Re: 62 Valiant?? [Re: 76dodgeboy] #693303
05/12/10 11:34 PM
05/12/10 11:34 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
you will need t ofind a v 8 center link for the 62,,,or the 3.9 will sit up kinda high to clear the center link,,,you can find them on e bay or another mopar site some times that deals with those early A bodies called for A-bodies only,
the dropped center link would fit 1964 65 66 only,valiant,dart,barracuda only,,,
the 1987 dakotas had 3.9 with a carb,,would be much easier then all the computer crap,,,i knew of a guy when i lived in ill he lived in the joliet area had a 1962 lancer or valiant??? with a 340 that was back in the early 1980s it can be done
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: 62 Valiant?? [Re: fstfish66] #693304
05/13/10 01:35 AM
05/13/10 01:35 AM
Iowa
Iowa
Fi would make it more fuel efficiant. The Magnum 3.9 has more Hp too. It wont be that hard if he can find a whole truck for the swap, than he would have all engine related parts. "IF" he does move forward on the swap we will have to look further into the centerlink. What els had the 3.9 other than the Dakota, Full size trucks and Vans? Might be able to mount it back enough to clear? I havent really look at the car to even get a feel for what would have to be done. Plus using a 3.9 if he decided to rebuild for power reasons it has the same cylinder bore as a 318 and he could get some good used higher comp pistons or if money is available a supercharger (procharger) or turbo it. Remember thier will be a bit of room front and back of the motor since it is shorter buy 3 cylinders
Re: 62 Valiant?? [Re: 76dodgeboy] #693305
05/13/10 10:39 PM
05/13/10 10:39 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
3.9 was available in full size trucks and full size vans. Usually, the full size trucks & vans are cheaper then Dakotas because the big stuff with a 3.9 was underpowered and resale value was low. Probably be easier to find a low milage full size truck with low miles cheap. Gene
Re: 62 Valiant?? [Re: poorboy] #693306
05/14/10 12:51 AM
05/14/10 12:51 AM
Iowa
Iowa
I dont know if the full size are cheaper around here.I havent seen may 3.9 fullsize around here but I also havent looked for a 94 up truck either. That needs further looking into Thanks If the 3.9 has the same oil pump as the 5.2 I think we could modify the 3.9 pan with a car pan tht will fit the 62 better. Like Ive said though. I havent looked at the slant in there to see what it could or might need done. Might not have to do anything.
Re: 62 Valiant?? [Re: 76dodgeboy] #693307
05/14/10 05:45 PM
05/14/10 05:45 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The oil pump is the same. The truck pan is a rear sump. You may be able to mount the 3.9 far enough forward to only need a notch in the back of the pan to clear the centerlink.
have pondered this swap for my 65 Cuda. If you mount the 3.9 as far forward as you can that opens up more real estate under the floor pan for the 4sp auto most of them are hooked to. Early A's require severe butchery to put a 4sp auto into one. Moving the V6 forwar as much as possible will not only give you more distributor to firewall clearance (62 A will need that) but it will remove most of the trans to tunnel interference issues.
Don't be the exception.
Re: 62 Valiant?? [Re: Supercuda] #693308
05/15/10 02:06 PM
05/15/10 02:06 PM
Iowa
Iowa
I know the current pan is rear sump. Thats why I said something about modifying it with a car pan to clear. Basically I would make a 3.9 Car pan is what I ment. It all depends. I havent looked at the bay of his car yet.Bang for buck its WAY cheaper than building the slant up to even meat the 3.9 Mag stock hp we could just stuff a Grand National motor in it NOT. I think itll be a fun build aslong as he want to actually do it and not just bs about doing it. I really want to help he do it
Re: 62 Valiant?? [Re: 76dodgeboy] #693309
04/12/11 02:13 AM
04/12/11 02:13 AM
dodge, washington
2
2manymopars Offline
2manymopars  Offline
dodge, washington
Hi ! Yeah, I know it is almost a year later but I was curious as to what became or what choice of power plant you decided on for the '62 Valiant ? The V8 choice is not difficult. I am currently running a 360 in my '62 Valiant wagon WITH a heater box still in place. Just trimmed and boxed in an area for the distributor to live in. Email me at: chargeray@aol.com I would be happy to share knowledge with you or anybody interested. Ray G.
Re: 62 Valiant?? [Re: 76dodgeboy] #693310
04/12/11 11:42 PM
04/12/11 11:42 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I think he needs to get his life in order before tackling any project.
He could buy a cheap transport device for less than either project.
Re: 62 Valiant?? [Re: RodStRace] #693311
04/14/11 07:39 PM
04/14/11 07:39 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Or it can be a great learning experience... Just saying. So long as someone is willing to help fund the project.
I knew a kid in high school who had his dad restore his 66 Mustang Conv. Basically whatever he payed for the car, his parents would match it. I think it's done being restored but I think he should have pulled a wrench or two. And it looks like such a girl's car. Not masculine at all.
Re: 62 Valiant?? [Re: MuuMuu101] #693312
04/14/11 08:53 PM
04/14/11 08:53 PM
Tracy CA
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
Tracy CA
Forget the heater, you can get universal units to replace it.
Then you can put whatever you want in it.
I'd ditch the 3.9 liter engine idea, that's about the most craptastic engine you could pick. Seriously. They are still dog slow and the mileage sucks. It may look good on paper but they just plain suck. Even Poly 318s make fun of the 3.9.
I'd go 360 or 440.
Re: 62 Valiant?? [Re: rabid scott] #693313
04/15/11 02:25 AM
04/15/11 02:25 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
I'd go 360 or 440.
i had a 3.9 in dakota carb,not injected, 5 speed was pretty pepppy,,,,not sure if mopar still makes a 4 bbl intake for a 3.9
2015 cherokee
2013 R/T classic
