Power assist adjustment #693271
05/09/10 05:14 PM
05/09/10 05:14 PM
Stow,Ohio
RBSat66 Offline OP
RBSat66  Offline OP
Stow,Ohio
Are there any articles or illistrations on how to adjust the power assist valve on a power steering gearbox?
Re: Power assist adjustment [Re: RBSat66] #693272
05/09/10 09:05 PM
05/09/10 09:05 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
All you can do to adjust it is to center it so it steers equally both ways. There isn't any adjustment to change the ammount of assist.
Re: Power assist adjustment [Re: stumpy] #693273
05/09/10 09:55 PM
05/09/10 09:55 PM
Stow,Ohio
RBSat66 Offline OP
RBSat66  Offline OP
Stow,Ohio
I probably explained it wrong, but I am trying to find out how to do what you just said. I'm looking for something with pictures to illustrate and describe what to do.
Re: Power assist adjustment [Re: RBSat66] #693274
05/09/10 10:19 PM
05/09/10 10:19 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Loosen up the two bolts that hold the valve just so they are still a little snug. With the engine running and the front wheels off the ground gently tap the valve up or down until the steering wheel stays still and turns equally as easy both ways. What kind of problem are you having with it now?
Re: Power assist adjustment [Re: stumpy] #693275
05/10/10 08:37 PM
05/10/10 08:37 PM
Stow,Ohio
RBSat66 Offline OP
RBSat66  Offline OP
Stow,Ohio
Turns easy to the left and hard to the right. Tends to go left under acceleration.
Re: Power assist adjustment [Re: RBSat66] #693276
05/10/10 08:47 PM
05/10/10 08:47 PM
Kirkland, Washington
Pacnorthcuda Offline
Stumpys explaination is correct...just beware...a tiny adjustment (fore/aft) makes a huge difference, with the front wheels off the ground they can go slaming to one side really easy. As he said, leave the bolts a little snug, just enough so you can tap slight movement into the valve plate.
